UDF for defining Heat Flux Profile at a wall
Like Tree9Likes
  • 1 Post By Alex90
  • 1 Post By ghost82
  • 2 Post By flotus1
  • 4 Post By flotus1
  • 1 Post By brunoc
Old   October 17, 2014, 12:15
Default UDF for defining Heat Flux Profile at a wall
Alex90 is on a distinguished road
Hi Guys, I am relativeley new to Ansys Fluent UDF Scripting and so far I did not get very far with my code ...
So what is my problem. I want to define an axial profile of the wall heat flux. I have a 4000mm long cylinder within Ansys the axis is orientated into z direction. The crux is that I have a constant wall heat flux within specific distances. For example from z>=0 to z<=300mm the heat flux q=0 and from z>300 to z<=600 the heat flux q=4738.666 .... and so on ....
Here is what I scripted so far :
#include "udf.h"
Define_Profile(heat_flux,thread,i)
face_t f;
begin_f_loop(f,thread)
if(x[2] <= 300)
F_PROFILE(f,thread,i) = 0;
else if(x[2] <= 600 && x[2] > 300)
F_PROFILE(f,thread,i) = 3500.955;
else if(x[2] <= 1050 && x[2] > 600)
F_PROFILE(f,thread,i) = 4738.666;
else if(x[2] <= 2100 && x[2] > 1050)
F_PROFILE(f,thread,i) = 4971.053;
else if(x[2] <= 2850 && x[2] > 2100)
F_PROFILE(f,thread,i) = 5092.298;
else if(x[2] <= 3300 && x[2] > 2850)
else if(x[2] <= 3600 && x[2] > 3300)
else if(x[2] <= 3900 && x[2] > 3600)
F_PROFILE(f,thread,i) = 2121.791;
else
end_f_loop(f,thread);
Unfortanetley this does not work. I wrote this with the code blocks editor and saved it as heat_flux.c , afterwards I compiled this within Fluent.
I got the following failure :
line 1 parse error ....
Can someone please help me with finding the failure. Thank you ...
SHREEKANT likes this.
Alex90 is offline   Reply With Quote
Old   October 17, 2014, 13:17
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi
you didn't hold the position vector.
Add
real x[ND_ND];
before face_t f
Define_Profile(heat_flux,thread,i) should be uppercase DEFINE_PROFILE(....)
Daniele
famon likes this.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   October 20, 2014, 05:32
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
After you added this, I think you still need to write the current face position to the variable x by adding
F_CENTROID (x,f,thread);
at the beginning of the face loop.
ghost82 and famon like this.
flotus1 is offline   Reply With Quote
Old   October 20, 2014, 09:43
Hi guys, i added what ghost82 wrote and tried it again. This time Fluent compiled it without failure. I did a steady calculation which finished after 1 iteration ... Post-Processing the results their is no single Heat Flux all over my geometry. I have the feeling that i did not specify geometry as flotus1 suggested ... so here is my second code :
#include "udf.h"
DEFINE_PROFILE(heat_flux,thread,i)
real x[ND_ND];
face_t f;
if(x[2] <= 300)
else
Thank you for your fast answers and your support
Old   October 20, 2014, 09:45
ghost82's Avatar
Rick
1 iteration??
Adjust number of iterations in the run tab and adjust residual values in the monitor tab to let the solution converge.
Old   October 20, 2014, 09:50
I addjusted the iterations number before the calculation to 100 ... I will try the residuals now ...
Old   October 20, 2014, 10:18
flotus1's Avatar
Alex
Did you add what I suggested? Otherwise the heat flux will be zero everywhere and it comes as no surprise that the solution of the energy equation converges after 1 iteration.
Old   October 20, 2014, 10:29
Hi Flotus you mean F_CENTROID ? ....
#include "udf.h"
real x[ND_ND];
face_t f;
if(x[2] <= 300)
Old   October 20, 2014, 11:44
flotus1's Avatar
Alex
Yes.
Additionally, keep in mind that Fluent expects values to be in SI-units. So "if(x[2] <= 300)" checks if the z-value is smaller than 300m.
Just to be sure I would rather enter these values with a decimal point, so 300.0 instead of 300 and F_PROFILE(f,thread,i) = 0.0; instead of F_PROFILE(f,thread,i) = 0;
ghost82, famon, SHREEKANT and 1 others like this.
Old   October 15, 2015, 05:16
Default Same query with angular way
SHREEKANT
SHREEKANT is on a distinguished road
I went through all your healthy discussions...
I want to give different heat flux values in a pipe in a angular way like,upper part of pipe receiving more heat than lower part.
That is, upper portion of 270 deg. receiving 550W/m2 and lower 90 deg. receiving 20000W/m2 of heat.
can anyone help me out of this issue?
SHREEKANT is offline   Reply With Quote
Old   October 20, 2015, 11:36
Bruno
brunoc is on a distinguished road
No need to use UDFs here. Just split your pipe into upper and lower regions, then set different boundary conditions at those.
salehorafi likes this.
brunoc is offline   Reply With Quote
Old   October 31, 2015, 07:35
SHREEKANT
Hi Brunoc,
Thank you for the reply. In that case, I am afraid about the ways by which inlet and outlet boundary condition can be given, as it is split as two halves. I have a mass flow inlet at the entrance section.
Old   September 10, 2016, 23:43
hussein
hussein92 is on a distinguished road
hi !!
my module is cooling PV cell
so the heat flux will be q*(1-efficiency of pv )
but the efficiency is function of temperature of pv T cell
efficincy= efficincy-ref *(1-0.004(T of cell -T ref))
how i can defined that in fluen
hussein92 is offline   Reply With Quote
Old   August 4, 2018, 06:34
Default heat flux for full and rot_periodic pipe
  #14
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
I want to test two models. One model is full circular pipe with solid wall modeled and has a heat flux of 3500 on its top wall.
Second model is 1/10 th of the circumference extruded in third dimension to get the pipe length. This also contains the solid mesh. The outer wall is again supplied with 3500 heat flux. The sides are periodic (rot. periodic)
Now I want to compute Tw at the interface and Tout at outlet and difference between the two. such that delta T = (Tw- (298.15+To)*0.5). 298.15 K is the inlet temperature.
Q: Why the delta T is different for two cases? Should I take some other flux value when modeling 1/10th of the geometry.
Shamoon Jamshed is offline   Reply With Quote
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 22:55
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
Heat Flux Profile at Fluid-Porous Interface Hitch8 CFX 4 December 15, 2012 10:57
UDF to calculate average heat flux dynamics Fluent UDF and Scheme Programming 0 July 21, 2012 19:54
heat flow UDF on coupled surface (wall-shadow wall) Friedmann Fluent UDF and Scheme Programming 0 August 5, 2010 11:25
