temperature varies with time
Like Tree1Likes
  • 1 Post By aozdogan
Old   October 7, 2014, 17:59
Default temperature varies with time
Ayse Ozdogan
aozdogan is on a distinguished road
Hi all,
I am trying to write a udf code to define boundary conditions for the inlet and outlet temperature that are varying with time. I create a txt/or c file, but I dont know how to read this file. Does anyone have experienced with this type problem?
Thanks
aozdogan is offline   Reply With Quote
Old   October 8, 2014, 11:32
Andrew Kokemoor
Kokemoor is on a distinguished road
You might be able to use profiles instead of UDFs. They're less powerful, but simpler. Check out Section 6.6 of the Fluent User's Guide.
Kokemoor is offline   Reply With Quote
Old   October 8, 2014, 11:39
François Grégoire
macfly is on a distinguished road
I would go for a DEFINE_PROFILE udf, see the examples in sections 2.3.19.10 and 2.3.19.11 of the UDF Manual release 15.0. Then read section 2.3.19.12 in order to know how to hook the boundary profile in your model.
macfly is offline   Reply With Quote
Old   October 8, 2014, 14:05
Ayse Ozdogan
thanks Kokemoor and macfly.
I went over all you mentioned here, but none of them has an example related to my problem. Since my experimental data is a large demand even though I cut off using monthly base temperature vs time, the best way to assign this data to fluent is to have txt file and read it by udf. I am still stuck how to manage
Old   October 9, 2014, 08:58
François Grégoire
Example 2.3.19.11 is perfectly related to your case with time-varying specification of a profile. If your case has a lot of time steps and a lot of if(CURRENT_TIME <= ...) you could automate the writing of the UDF in Python, Matlab or any other programming language.
Old   October 9, 2014, 12:01
Default got a code working :)
Ayse Ozdogan
thanks macfly! your are right it is exactly matching with my problem except that I have a lots of case file.I looked at the fluent 14.5 release but I just found fluent 15. Anyway, finally I got my code is working know. Here is my code;
#include "udf.h"
#include "mem.h"
double time;
double timef[51], temp1f[51], temp2f[51];
int vcount=0;
FILE *fp;
DEFINE_INIT(read_file, d)
/*reads data from file and stores as global variables*/
int i;
fp=fopen("timevstemp.txt", "r");
for (i=0;i<51; i++){
fscanf(fp,"%lf %lf %lf", &timef[i], &temp1f[i], &temp2f[i]);
fclose(fp);
printf(" %f %f %f %\n", timef[0], temp1f[0], temp2f[0]);
DEFINE_PROFILE(tempout, t, nv)
face_t f;
double x[ND_ND];
int row1=1; /*initalize row to 1*/
int prow1=0;
double Tout;
time=CURRENT_TIME;
while((time) >= timef[row1] ){
row1=row1+1;
prow1=row1-1;
Tout= 273.15+ temp1f[prow1] + ((time)-(timef[prow1]))*(temp1f[row1] - temp1f[prow1])/
(timef[row1]-timef[prow1]);
printf(" Tout %f temp1 %f tempf %f \n",Tout, temp1f[prow1], temp1f[row1]);
begin_f_loop(f, t)
F_CENTROID(x,f,t);
F_PROFILE(f,t,nv)= Tout;
end_f_loop(f,t)
DEFINE_PROFILE(tempin, t, nv)
face_t f;
double x[ND_ND];
int prow1=0;
double Tin;
time=CURRENT_TIME;
row1=row1+1;
prow1=row1-1;
Tin= 273.15+ temp2f[prow1] + ((time)-(timef[prow1]))*(temp2f[row1] - temp2f[prow1])/
(timef[row1] - timef[prow1]);
begin_f_loop(f, t)
F_CENTROID(x,f,t);
F_PROFILE(f,t,nv)= Tin;
end_f_loop(f,t)
macfly likes this.
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Transient simulation : Static temperature and time averaged static temperature saisanthoshm88 CFX 4 July 4, 2013 03:18
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
