DEFINE_PROPERTY for solid density
Like Tree1Likes
  • 1 Post By macfly
Old   September 28, 2014, 03:29
Default DEFINE_PROPERTY for solid density
François Grégoire
macfly is on a distinguished road
I'm trying to set the density of aluminum via a very simple interpreted DEFINE_PROPERTY udf :
#include "udf.h"
DEFINE_PROPERTY(my_density, c, t)
real rho;
rho=1000;
return rho;
I don't understand why it doesn't work, after the solution is converged Fluent returns that the density of aluminum is the default value of 2719 kg/m³, see the pictures. What am I missing? (and yes, I click the Change/Create button before closing the Create/Edit Materials window)
macfly is offline   Reply With Quote
Old   September 28, 2014, 05:20
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Maybe a bug?
Here is the same problem:
http://www.cfd-online.com/Forums/flu...d-density.html
However it seems fluent use the custom defined values for calculation.
Which fluent version do you have?
ghost82 is offline   Reply With Quote
Old   September 28, 2014, 08:21
François Grégoire
Yes, I saw that other thread.
I'm using 14.5.7
Old   September 28, 2014, 14:41
François Grégoire
My udf works fine for setting the Specific Heat or Thermal Conductivity, it's just with the Density that it doesn't work.
Old   September 29, 2014, 01:29
François Grégoire
Ok I retrieved the value of the solid density with C_R(c,t) within a DEFINE_EXECUTE_AT_END macro and I get the value I set in my udf. It looks as if it's just a postprocessing bug.
ghost82 likes this.
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
How to model Salinity, density, fresh water & sea water grayback87 FLUENT 3 December 30, 2014 03:00
A problem about density in liquid air definition alloveyou CFX 2 June 14, 2012 15:20
REAL GAS UDF brian FLUENT 6 September 11, 2006 09:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
