Please help UDF error!!!!
Like Tree2Likes
  • 1 Post By pakk
  • 1 Post By upeksa
Old   September 25, 2014, 01:34
Default Please help UDF error!!!!
Anh
dinhanh is on a distinguished road
Hi everyone, I am new in CFD. I try to make a simple udf: DEFINE_SOURCE as below. But when complied show the error.
#include "udf.h"
#include "math.h"
#include "sg.h"
#include "sg_mphase.h"
#include "flow.h"
#include "mem.h"
#include "metric.h"
#define Cpl 4184
#define Cpv 2014
#define h0l 1143000
#define h0v 1982000
#define Rb 0.000001
#define anuc 0.0005
#define Fvar 50
#define Fcond 0.01
#define pk 22130000
#define Tk 647.31
#define a 7.21379
#define b 0.00001152
#define c -0.000000004787
#define d 483.16
#define Rhol 998.6
#define Rhov 0.02435
DEFINE_SOURCE(energy_source, c, t, dS, i)
real Pv;
real dp;
real me;
real mc;
real L;
real source;
int liquid=0;
int vapor =1;
Thread *phase1;
Thread *phase2;
phase1=THREAD_SUB_THREAD(t,liquid);
phase2=THREAD_SUB_THREAD(t,vapor );
Pv=pk*exp((1.0-Tk/C_T(c,t))*(a+(b+c*C_T(c,t))*(C_T(c,t)-d)*(C_T(c,t)-d)));
voidf=C_VOF(c,phase2);
dp =C_P(c,t)-Pv;
if(dp<0)
me=Fvar*3.0*anuc*(1.0-voidf)*Rhov*sqrt(2.0*abs(dp)/Rhol/3.0)/Rb;
mc=0.0;
else
mc=Fcond*3.0*voidf*Rhov*sqrt(2.0*abs(dp)/Rhol/3.0)/Rb;
me=0.0;
L=(Cpv*C_T(c,t)+h0v)-(Cpl*C_T(c,t)+h0l);
source=-L*(me-mc);
dS[i]=0.0
return source;
Program error message
for d in lnamd64/[23]*; do \
cd $d; \
for f in ../../src/*.[ch] ../../src/makefile; do \
if [ ! -f `basename $f` ]; then \
echo "# linking to" $f "in" $d; \
ln -s $f .; \
fi; \
done; \
echo ""; \
echo "# building library in" $d; \
if [ "" = "1" ]; then \
echo "# using gcc64"; \
make ARCHC=gcc64 -k>makelog 2>&1; \
else \
echo "# using gcc"; \
make ARCHC=gcc -k>makelog 2>&1; \
else \
make -k>makelog 2>&1; \
fi; \
fi;\
cat makelog; \
done
# linking to ../../src/Energy_source.c in lnamd64/3d
# building library in lnamd64/3d
make[1]:
ディレクトリ `/home/CFb/CFb003/Exp_Data/Energy_effect/libudf1/lnamd64/3d' に入ります
# Generating udf_names.c because of makefile Energy_source.c
make[2]:
make libudf.so "CFLAGS=-D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= " "LDFLAGS=-shared -lm"
make[3]:
# Compiling udf_names.o because of udf_names.c
cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/cortex/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/client/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/tgrid/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/mpi_wrapper/include -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/mpi_wrapper/src -I. -c udf_names.c
# Compiling Energy_source.o because of Energy_source.c
cc -D_lnamd64 -D_GNU_SOURCE -fpic -shared -ansi -Wall -O -DPTR_RESTRICT= -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/`expr "\`pwd\`" : '.*/\(.*\)/[23].*'`/`basename "\`pwd\`"` -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/cortex/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/client/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/tgrid/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/src -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/mpi_wrapper/include -I/ap/ANSYS/ansys_inc/v145/fluent/fluent14.5.7/multiport/mpi_wrapper/src -I. -c Energy_source.c
Energy_source.c:26: error: expected ‘;’, ‘,’ or ‘)’ before ‘-’ token
make[3]: *** [Energy_source.o]
エラー 1
make[3]:
ターゲット `libudf.so' はエラーにより再 make できませんでした.
make[3]:
ディレクトリ `/home/CFb/CFb003/Exp_Data/Energy_effect/libudf1/lnamd64/3d' から出ます
make[2]: *** [lnamd64]
エラー 2
make[2]:
make[1]: *** [default]
エラー 2
make[1]:
How could I fix this error? Plese help, thank you in advance!!!
dinhanh is offline   Reply With Quote
Old   September 25, 2014, 05:06
pakk will become famous soon enough
The problem is that you use the variable "c" two times.
Once in your definition in line 21, where you define it as a number. And the second time in line 26, where you define it as a variable.
You line 21 tells to the compiler: "every time I write the letter c, replace it by the number -0.000000004787".
So when the compiler reaches line 26, it reads:
DEFINE_SOURCE(energy_source, -0.000000004787, t, dS, i)
And that does not make any sense, since a variable name is expected there. Once the compiler reads the minus sign, it knows there is a problem, so that explains your error.
Edit: To solve it, you should rename one of the two c's. I would advice to rename the first one (in line 21), but either option works.
dinhanh likes this.
pakk is offline   Reply With Quote
upeksa is on a distinguished road
You have defined "c" twice: as a constant and as a cell_t type argument in DEFINE_SOURCE.
Check this line: dS[i]=0.0;
Cheers
dinhanh likes this.
upeksa is offline   Reply With Quote
Old   September 26, 2014, 05:10
Anh
Thank you very much, Upeksa and Pakk
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
