the oscillatory shear index (OSI)
Like Tree2Likes
  • 1 Post By siamak1438
  • 1 Post By ftab
Old   September 22, 2014, 03:11
Default the oscillatory shear index (OSI)
Siamak
siamak1438 is on a distinguished road
The oscillatory shear index (OSI) is an important factor in hemodynamic use to measure disturbed flow along the artery wall. As you can see form the following formula (attached picture) it must be calculate after one cycle. In this formula T is the period of the one cycle. In the other hand, during one cycle, the shear stress on the artery wall must be integrated. So, I think to doing this calculation, I have to write UDF or even I have to develop code in Matlab or C++. I am wondering, is there anyone do it before? Can you guide me how can I do it?
Yours,
Siamak
presidentmamun likes this.
siamak1438 is offline   Reply With Quote
Old   September 24, 2014, 06:51
Ftab
ftab is on a distinguished road
Hi Siamak,
I have done it exporting the WSS data of each time step to a file with a UDF.
Then, I actually calculate everything in Matlab simply with Trapezoidal integration, and then having the connectivity of the nodes and information of the faces I plot it in Tecplot.
The matlab code is very simple, the only concern is to export the XYZ of nodes and the connectivity of them to make triangular faces to a file to use it later to construct the plot in Tecplot.
Cheers,
Ftab
siamak1438 likes this.
ftab is offline   Reply With Quote
Old   December 12, 2014, 16:39
Emily Imdieke
emily.imdieke is on a distinguished road
Do you have to use integration though? Can't you just use the WSS components at each point?
emily.imdieke is offline   Reply With Quote
Old   April 21, 2015, 10:44
Ftab
By the definition, OSI is the integration over the cardiac Cycle!
Oscillatory Shear Index Calculation ashtonJ CFX 39 December 6, 2023 02:24
UDF for calculating Oscillatory Shear Index (OSI) vasava Fluent UDF and Scheme Programming 24 April 20, 2023 06:48
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 06:48
