Loading library via scheme command
Like Tree1Likes
  • 1 Post By pakk
Old   September 18, 2014, 10:04
Question Loading library via scheme command
crevoise is on a distinguished road
Hello
It might seem a silly question. I wish to load some user defined udf library and to make this procedure automatic by scheme command, saved in a .scm file.
1) Within the Fluent interface, the library loading is done normally by: Define>User-defined>function>manage.
2) In the fluent environment, the following scheme command do the loading of the library:
(ti-open-udf-library)load libudf
3)However, I wish to save this procedure into a .scm file, to be opened via file>read>scheme
When executing the .scm file, fluent is stoping after the first command (ti-open-udf-library) and request to give the answer to load/unload/compile. This is not really what i was looking for, as the aim was not to have to interact.
My question is: why, while reading the .scm file, fluent is stopping at the first scheme command (while it does not if I am writing it directly on the fluent window, and access the load command by itself)
Does anyone knows how to overcome this issue?
Thanks for any help
crevoise is offline   Reply With Quote
Old   March 31, 2017, 05:01
Rosario Arnau
rarnaunot is on a distinguished road
Hi!
I have almost the same problem. How do you solve that?
I've been thinking to use DEFINE_EXECUTE_ON_LOADING or EXECUTE_ON_LOADING but I don't know the difference
Thanks in advance
rarnaunot is offline   Reply With Quote
Old   March 31, 2017, 05:23
pakk will become famous soon enough
For me, the following works:
(open-udf-library "libudf")
Assuming that "libudf" is already compiled.
rarnaunot likes this.
pakk is offline   Reply With Quote
Old   March 31, 2017, 07:50
Rosario Arnau
Thanks!
I'll tried it! I found that more effective that trying another UDF with execute on loading or another macros.
library, scheme
ERROR: unable to find library HJH CFX 6 February 26, 2019 07:52
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 22:20
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
SCHEME command to write XY plot to file? Angelo Sozzi FLUENT 1 July 22, 2004 17:54
