Divergence with source UDF for VOF
Like Tree2Likes
  • 2 Post By Sun
Old   September 2, 2014, 23:42
Default Divergence with source UDF for VOF
aleni32 is on a distinguished road
Hi everybody
I wrote an UDF for sources (lift, drag, virtual mass forces and K and epsilon) for VOF model two phase(steel and injecting argon). the simulation converged without sources but when the source became activated the simulation diverged suddenly after 1.5 sec with this error:sweeping relaxation factors, divergence in X momentum y momentum, z, k , epsilon- divergence detected in AMG solver: x-momentum', floating point exception .
Global Courant number was stable before divergence.
I did the following procedures:
1- limiting the sources to just above argon inlet and below the free surface
2- changing the URF of sources from 0.1 to 0.05
but still diverging suddenly. I really dont have any idea whether it is a structural error in sources or errors in setting of fluent.
Much appreciated if anybody help me to find the error.
aleni32 is offline   Reply With Quote
Old   September 3, 2014, 02:51
Sun
Sun's Avatar
Sun is on a distinguished road
Since you mentioned that it worked without the source term, something might be wrong with the source term calculation. If you share your UDF with a short description, I'll have a look. The "floating point exception" error usually happens due to a bad math throughout the code such as division by zero or some variables go to infinity and etc.
aleni32 and 6863523 like this.
Sun is offline   Reply With Quote
Old   September 3, 2014, 07:51
Default your email
Dear SUN
I would be appreciated if you give me your email. I would send my UDF to you.
Thanks in advance
Old   September 3, 2014, 11:55
Sun
Sun's Avatar
You can send it via private message.
Old   December 28, 2014, 02:16
rishitosh's Avatar
Rishitosh Ranjan
rishitosh is on a distinguished road
I m also facing same prlm...
rishitosh is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
help on UDF mass source shao1 FLUENT 2 July 11, 2002 21:36
