Execute_ At_ End udf for Time dependent toruqe
Like Tree1Likes
  • 1 Post By GM_XIII
Old   July 13, 2014, 03:09
Default Execute_ At_ End udf for Time dependent toruqe
shashank mishra
shashankmechguy is on a distinguished road
Hi All,
I am using udf Execute_At_End to print in console time dependent value of torque.
The problem I have is , the example given in fluent udf manual is for entire domain. I only want to calculate torque for one boundary zone which is a face thread of blades of a rotor.
This is the code I am using
#include"udf.h"
DEFINE_EXECUTE_AT_END(torque_time)
Domain *d;
Thread *t;
face_t f;
real NV_VEC(A);
real NV_VEC(force);
real NV_VEC(torque);
real x[ND_ND];
real NV_VEC(radius);
real NV_VEC(torque_final);
real tor;
NV_S(force,= ,0.0);
NV_S(torque_final,= ,0.0);
NV_S(torque,= ,0.0);
d = Get_Domain(9);
begin_f_loop(f,t)
F_AREA(A,f,t);
F_CENTROID(x,f,t);
NV_S(force,= , F_AREA(A,f,t), * , F_P(f,t));
NV_D(radius,= ,x[0],x[1],x[2]);
NV_CROSS(torque,radius,force);
NV_VV(torque_final,= ,torque_final,+, torque);
tor= NV_MAG(torque_final);
end_f_loop(f,t)
printf("Value of torque at the blades is = %f", tor );
I used d= Get_Domain(9) because the integer id of that face thread is 9. But its not printing anything on the console and I know I cannot use Get_Domain(9).
Can anyone advise me how to specify one particular face thread for execute_at_end macro
shashankmechguy is offline   Reply With Quote
Old   July 15, 2014, 11:35
David
GM_XIII is on a distinguished road
you need to do the following:
d=Get_Domain(1);
t = Lookup_Thread(d, Zone_ID); /*Here is where you give the id read in BC as zone_id*/
shashankmechguy likes this.
GM_XIII is offline   Reply With Quote
Old   July 15, 2014, 16:04
shashank mishra
Thanks David,
but still I am not able to print anything in console window.
I dont know why. There is no error while compiling or interpreting this udf.
Old   July 16, 2014, 08:11
David
Your case is multiphase? Have you tried changing the ZOne_id? Post here the new UDF code
Old   July 16, 2014, 22:30
shashank mishra
It started working once I changed the printf to message but now I am getting
received a fatal signal : Segmentation violation.
Old   July 16, 2014, 22:32
shashank mishra
Here is the UDF Code:
#include"udf.h"
Domain *d;
Thread *t;
face_t f;
real NV_VEC(A);
real NV_VEC(force);
real x[ND_ND];
real tor;
NV_S(force,= ,0.0);
d = Get_Domain(1);
t = Lookup_Thread(d, 12);
begin_f_loop(f,t)
F_AREA(A,f,t);
F_CENTROID(x,f,t);
end_f_loop(f,t)
Message("Value of torque at the blades is = %f", tor );
I am running Fluent on Linux.
Old   July 17, 2014, 02:10
blackmask will become famous soon enough
can your code be compiled at all?
IMO,
should be replaced by
 F_AREA(A,f,t);
NV_VS(force,= , A, * , F_P(f,t));
blackmask is offline   Reply With Quote
Old   July 17, 2014, 03:12
shashank mishra
IMO,
 F_AREA(A,f,t);
Hi BlackMask,
Thanks for the input. I made that correction.
And now I am getting at least print message with value always =0.000.
I thought I am doing something wrong with cross product so I tried printing force value, still 0.000. Then for the sake of checking, I tried printing sum of area values, that is also 0.000.
I dont know what is wrong in the logic of udf?
Old   July 17, 2014, 20:54
Make sure that your thread id is correct. What is the result of
printf("%d\n", THREAD_ID(t));
Radiation interface hinca CFX 15 January 26, 2014 18:11
particle tracking sakurabogoda CFX 7 December 5, 2013 00:12
cyclone separator particle tracking prob.. sakurabogoda CFX 33 May 29, 2013 07:36
How tensor parameters to be entered in CFX-pre? hadi.iraji CFX 1 May 7, 2013 05:03
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
