Monitor a variable of a UDF
Like Tree1Likes
  • 1 Post By ChristophGradl
Old   June 13, 2014, 05:12
Default Monitor a variable of a UDF
Christoph Gradl
ChristophGradl is on a distinguished road
I want to use a monitor in fluent to plot the value of a variable of a UDF.
Is there a possibility in fluent?
I only found the possibility to write the values to a file.
For example I want to monitor the variable v_prev:
     DEFINE_CG_MOTION(piston, dt, vel, omega, time, dtime)  {
 Thread *t;
 face_t f;
 real NV_VEC (A);
 real force, dv;
 /* reset velocities */
 NV_S (vel, =, 0.0);
 NV_S (omega, =, 0.0);
 if (!Data_Valid_P ())
 return;
      /* get the thread pointer for which this motion is defined */
       t = DT_THREAD ((Dynamic_Thread *)dt);
 /* compute pressure force on body by looping through all faces */
 force = 0.0;      begin_f_loop (f, t)
           F_AREA (A, f, t);
          force += F_P (f, t) * NV_MAG (A);
      end_f_loop (f, t)
         /* compute change in velocity, i.e., dv= F * dt/ mass;         velocity update using explicit eulerformula */
      dv= dtime* force / 50.0;
       v_prev+= dv;
         CX_Message ("time = %f, x_vel= %f, force = %f\n", time, v_prev, force);
      /* set x-component of velocity */
       vel[0] = v_prev;
Thank you for any suggestions,
Christoph
Chong070940103 likes this.
ChristophGradl is offline   Reply With Quote
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:51
name variable in UDF using Thread : syntax error before numeric constant Laurence Wallian FLUENT 0 October 8, 2009 10:18
UDF: exporting a variable between two DEFINE function Carlo FLUENT 3 August 19, 2009 13:21
Yplus UDF variable Matthew Brannock FLUENT 0 June 23, 2003 04:41
