An odd ERROR
Like Tree3Likes
  • 1 Post By Galileo
  • 1 Post By Galileo
  • 1 Post By Galileo
Old   April 15, 2014, 09:27
Post An odd ERROR
mdakbari's Avatar
m.akbari
mdakbari is on a distinguished road
hi friends, i have a problem in interpreting my .c file
when i interpret it by fluent, an error appears that says:
label "temp" not found (pc=61)
so what does it mean?
i really need ur help dudes.
my code is below:
UDF
all calculations for al2o3 nanoparticles
#include "udf.h"
#define FI 0.01
#define RHO_np 3600
#define SI_1 0.9830
#define SI_2 12.959
DEFINE_PROPERTY(cell_conductivity,cell,thread)
real ktc;
real temp = C_T(cell,thread);
ktc = (-8.354*0.000001*(pow(temp,2)))+((6.53*0.001*temp)-0.5981);
return ktc;
DEFINE_PROPERTY(cell_density,cell,thread)
real rho_w = (-3.570*(pow(10,-3))*(pow(temp,2))+(1.88*temp+753.2));
real rho = (FI*RHO_np)+((1-FI)*rho_w);
return rho;
DEFINE_PROPERTY(cell_viscosity,cell,thread)
real mu_w,mu;
mu_w = (2.591*(pow(10,-5))*(pow(10,(238.3/(temp-143.2)))));
mu = (SI_1*exp (SI_2*FI)*mu_w);
return mu;
mdakbari is offline   Reply With Quote
Old   April 15, 2014, 10:09
Engr Adeniyi
Galileo is on a distinguished road
Try this,
declare all variables before assigning values to them, for example,
real x, y, z;
x=4.;
y=10.;
z=0.3;
Instead of
real x= 4.;
real y=10.;
real z=0.3;
NB:
Your error is in this line, you used temp before declaring it:
mdakbari likes this.
Galileo is offline   Reply With Quote
Old   April 16, 2014, 03:22
Post my error
mdakbari's Avatar
m.akbari
Originally Posted by Galileo View Post
Try this,
real x, y, z;
x=4.;
y=10.;
z=0.3;
Instead of
real x= 4.;
real y=10.;
real z=0.3;
NB:
hello my friend, thank u for ur help. i did that correction and it did work. but unfortunately when i run the calculations, the calculations do not run and there would be an error, so i ask u to look at my full and entire code which i just completed it, and give me ur opinion with regard to the exact error which appeared in fluent:
Fluent UDF
Author: Milan
#include "udf.h"
#define FI 0.01
#define RHO_np 3600
#define SI_1 0.9830
#define SI_2 12.959
#define KTC_np 36
#define TI 5*(pow(10,4))
#define BETA_1 8.4407
#define BETA_2 -1.07304
#define CP_w 4200
#define KA 1.383*(pow(10,-23))
#define SIi_1 2.8217*(pow(10,-2))
#define SIi_2 3.917*(pow(10,-3))
#define SIi_3 -3.0669*(pow(10,-2))
#define SIi_4 -3.91123*(pow(10,-3))
#define T_0 298.15
#define D_np 59*(pow(10,-9))
#define CP_np 765
real ktc,ktc_w;
real f = ((SIi_1*FI+SIi_2*temp)/T_0)+(SIi_3*FI+SIi_4);
real beta = BETA_1*(pow(100*FI,BETA_2));
ktc_w = (-8.354*0.000001*(pow(temp,2)))+((6.53*0.001*temp)-0.5981);
ktc = ((KTC_np+(2*ktc_w)-2*(ktc_w-KTC_np)*FI)/(KTC_np+(2*ktc_w)+(ktc_w-KTC_np)*FI))+(TI*beta*FI*rho_w*CP_w*(pow(((KA*temp )/(RHO_np*D_np)),0.5))*f);
return ktc;
return rho;
real mu,mu_w;
mu = (SI_1*exp(SI_2*FI)*mu_w);
return mu;
DEFINE_PROPERTY(cell_specificheat,cell,thread)
real cp,rho_w,rho;
cp=(FI*RHO_np*CP_np)+(((1-FI)*rho_w*CP_w)/rho);
return cp;
and the error appeared when running the calculations:
Warning: D:\\mansys\\c\\c bank\\nanofluid\\nano---combined.c: line 26: Warning: D:\\mansys\\c\\c bank\\nanofluid\\nano---combined.c: line 38: Warning: D:\\mansys\\c\\c bank\\nanofluid\\nano---combined.c: line 46: Warning: D:\\mansys\\c\\c bank\\nanoflui
\\nano---combined.c: line 55:
Error: received a fatal signal (Segmentation fault).
Error Object: #f
Old   April 16, 2014, 12:14
Engr Adeniyi
NB: I did not run the code, but I think it should work now. You need to check through the edits shown in red to make sure the variables are spelt correctly. Please let me know if the errors persist.
Try and compile instead of interpreting before replying just in case it gives an error.
Fluent UDF
Author: Milan
#include "udf.h"
#define FI 0.01
#define RHO_np 3600
#define SI_1 0.9830
#define SI_2 12.959
#define KTC_np 36
#define TI 5.E4
#define CP_w 4200
#define KA 1.383E-23
#define SIi_1 2.8217E-2
#define SIi_2 3.917E-3
#define SIi_3 -3.0669E-2
#define SIi_4 -3.91123E-3
#define T_0 298.15
#define D_np 59.E-9
#define CP_np 765
{/*Declare variables first before using them */
real temp, ktc,ktc_w, f,beta,rho_w;
real dummy ;
/*Avoid too long equations,
split the equation into small parts but make sure it does not cause a bug*/
ktc =(TI*beta*FI*rho_w*CP_w*(pow(((KA*temp )/(RHO_np*D_np)),0.5))*f);
dummy =(KTC_np+(2*ktc_w)+(ktc_w-KTC_np)*FI);
ktc = ((KTC_np+(2*ktc_w)-2*(ktc_w-KTC_np)*FI)/dummy)+ ktc;
return ktc;
real temp, rho, rho_w;
return rho;
real temp,mu,mu_w;
return mu;
{real temp, cp,rho_w,rho;
return cp;
Old   April 17, 2014, 09:01
Default found the bug
mdakbari's Avatar
m.akbari
Fluent UDF
Author: Milan
#include "udf.h"
#define FI 0.01
#define RHO_np 3600
#define SI_1 0.9830
#define SI_2 12.959
#define KTC_np 36
#define TI 5.E4
#define CP_w 4200
#define T_0 298.15
#define D_np 59.E-9
#define CP_np 765
real dummy ;
return ktc;
return rho;
real temp,mu,mu_w;
return mu;
return cp;
hello my friend mr. galileo, i really appreciate ur help. ur so so kind.
i used the code that u have written but the errors appeared again. however finally found why it is happening, its the specific heat part . now i know the problem, its because of the way and the macro we must define specific heat with. so i modified the code. now no error would occur by compiling the code in fluent or by running the calcs.
but i'm not sure that my specific heat part is correct. whatever the modified code is below, i am really keen to have new comments.
Fluent UDF
Author: Milan
#include "udf.h"
#define FI 0.01
#define RHO_np 3600
#define SI_1 0.9830
#define SI_2 12.959
#define KTC_np 36
#define TI 5.E4
#define CP_w 4200
#define T_0 298.15
#define D_np 59.E-9
#define CP_np 765
real ktc,ktc_w,temp,f,beta,rho_w;
return ktc;
real temp,rho_w,rho;
return rho;
real mu,mu_w,temp;
return mu;
DEFINE_SPECIFIC_HEAT(specificheat, T, Tref, h, yi)
real cp,rho_w,rho;
rho_w = (-3.570*(pow(10,-3))*(pow(T,2))+(1.88*T+753.2));
cp = (FI*RHO_np*CP_np)+(((1-FI)*rho_w*CP_w)/rho);
return cp;
Old   April 17, 2014, 12:29
Engr Adeniyi
Are you compiling or interpreting the code? Good to hear the code now runs with no error. What else do you want to know? If the Cp is correct I suppose? That is not a UDF question in my own view. You will need to know how you formulated the equations, perhaps from a journal paper or a text book reference or a data fit. All you need to do is do the same equation in Excel and see if it is giving what you want it to give. If you are compiling the code, you can put CX_Message("Cp= %E \n", cp); before the return cp; line so that it will display the values used in the simulation.
Old   April 18, 2014, 03:22
mdakbari's Avatar
m.akbari
ok, thanks for ur help along making my code, i will update this page if the code was mistake and caused errors,
again thanks
Old   April 4, 2016, 05:30
Andrew Vella
Lancashire is on a distinguished road
Dear All,
I have just compiled the above UDF for the specific heat of Al2O3 nanofluids in FLUENT. The UDF was compiled and the CASE file was initialised with no errors. However, as soon as I initiated the calculations, I was prompted with a solver error due to a diverging temperature. This was not the case with a constant Cp and with the UDFs for density, conductivity and viscosity. Hence, my suspicion is that the cause of this error is Tref. Hence do we need to specify a reference temperature?
Thanks in advance!
Lancashire is offline   Reply With Quote
error, udf
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
