craziest problem
Like Tree1Likes
  • 1 Post By Galileo
Old   April 13, 2014, 04:44
Angry craziest problem
sajjad taghavi
sajjad taghavi is on a distinguished road
Hi everybody
I wrote a UDF, compile it and load its library without any problem. But when I want to initialize the UDS parameters which I defined in my UDF, I face to this error:
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
What should I do to solve this problem?
sajjad taghavi is offline   Reply With Quote
Old   April 15, 2014, 05:05
Engr Adeniyi
Galileo is on a distinguished road
Originally Posted by sajjad taghavi View Post
Hi everybody
Error:
Error Object: ()
It will be difficult to help you without seeing your code.
Meanwhile if your code requires allocating UDM you may need to specify memory/node locations in the GUI.
Another point is if you compiled in a different machine or on different number of cores to the current machine, you will get some errors.
You could also get Access violation error if you attempt to call a variable that is not available in the solver. For example if you are running an isothermal problem and you attempt to call temperature C_T or you are running a laminar problem and you attempt to call turbulent kinetic energy etc.
Hope it helps. Cheers.
mdakbari likes this.
Galileo is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
