UDF for improved coal devolatilization model in fluent(devolatilization ) |
September 28, 2013, 12:05 |
ccc
Recently I use Fluent to simulate coal gasification under hydrogen atomosphere with the EDC model taking detailed reactions into account.
However, the volatile is thought as one compound named COAL-HV in the default CPD model embedded in Fluent, in fact it composes of several simple components(H2, CH4,CO CO2, H2O etc.). I want to know how to write a UDF to divide volatile into detailed components? Furthermore, the FG-DVC model and FLASHCHAIN model also can predict the detailed species in the volatile matters. The above two model is not available in the FLUENT software, and UDFs is needed to implement the model. Any suggestions will be very helpful... Thank you very much in advance... PLS share yr UDFs with me magic08016@gmail.com |
July 6, 2016, 05:16 |
Nebojsa Manic
Rep Power: 16 |
If You didn't find solution yet, just to inform You that I'm dealing with the same simulations and I will try to incorporate FG-DVC model through UDF.
I will inform You about my progress. Also if someone already done something in this field it would be very nice to share with us. |
April 8, 2017, 02:28 |
help in coal devolatilization model UDF
#3 | |
Jiangkuan Xing
Rep Power: 9 |
J.K. Xing Zhejiang University, P.R China. |
May 23, 2023, 06:18 |
Zhang yiran
Hello, I have a similar question, could you please tell me how do you solve this problem?Thank you!
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
A question about UDF utility in mixture and multiphase model | aleisia | Fluent UDF and Scheme Programming | 0 | June 7, 2011 17:32 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 15:07 |
UDF for Herschel-Bulkely model | emad | Fluent UDF and Scheme Programming | 5 | July 20, 2009 09:16 |
The problem of UDF in Non premixed combustion model | zhangyuan | Main CFD Forum | 0 | May 25, 2009 10:41 |
