udf temperature
Like Tree1Likes
  • 1 Post By kornetka
Old   September 24, 2013, 05:22
Default udf temperature
rayan
rayan24 is on a distinguished road
I want to impose a different temperature a different time, i want to impose 700K between t=0 and t=10s and T=400 K between t=10s and t=50s, can you see this udf and suggest me a correction, please?
#include "udf.h"
DEFINE_PROFILE(inlet_temperature,t,i)
real x[ND_ND];
real r;
face_t f;
real dt=CURRENT_TIME;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
if ( dt <= 10)
F_PROFILE(f,t,i) =700;
if (10 < dt <= 50)
    F_PROFILE(f,t,i) =400;
end_f_loop(f,t)
rayan24 is offline   Reply With Quote
Old   September 24, 2013, 16:13
kornetka's Avatar
kornetka is on a distinguished road
two things I noticed:
1. Try changing the 2nd if statement into conjuction of conditions, i.e.
10 < dt && dt <= 50
2. I think that values for both cases (F_PROFILE=...) should be inside the face loop.
Hope this helps,
Regards, kornetka
rayan24 likes this.
kornetka is offline   Reply With Quote
Old   September 25, 2013, 09:57
rayan
Yes! good
Thanks
UDF for Temperature Dependent Energy Source er.mkumar Fluent UDF and Scheme Programming 9 March 14, 2024 05:01
UDF temperature profile asal Fluent UDF and Scheme Programming 67 August 7, 2018 13:41
UDF slip and temperature jump from IFRT abir Fluent UDF and Scheme Programming 1 July 30, 2012 06:44
UDF or any approach for Bulk Temperature calculation vemps FLUENT 0 May 1, 2009 02:09
UDF reading the temperature gradient Fabian FLUENT 1 May 29, 2003 21:18
