UDF for a 3D inlet velocity profile with wave motion
Like Tree3Likes
  • 2 Post By kailingkk
  • 1 Post By czhao86
Old   September 13, 2013, 07:39
Default UDF for a 3D inlet velocity profile with wave motion
Kai Ling
kailingkk is on a distinguished road
I am a new user of FLUENT. I am required to do a 3D simulation a immersing a box into the sea.
For testing sake, I have came out with a UDF code for a 3d inlet velocity profile with wave motion in the x-direction with a moving object in the water.
For modelling, I built a small box and a big box encasing it, hoping to be able to simulate the dropping of the small box into the waters (2 phase fluid in the big box). The model was a 3D model.
However, I have encountered this error "The UDF library you are trying to load is not compiled for 3D on the current platform (win64). \libudf\win64\3d\libudf.dll"
Could anyone tell me what went wrong? Would really appreciate it!
Thank you
mjzganji and saghi123 like this.
kailingkk is offline   Reply With Quote
Old   September 13, 2013, 09:00
Giuseppe Tescione
DartPeppe is on a distinguished road
this is my first time on this forum,
please, forgive my ignorance and my poor English.
my problem is basically the same as kailingkk
The question that I propose has already been addressed, I read and followed the discussions but have not been able to solve the problem.
I'm trying to perform an application / tutorial "heave and pitch simulation of ship hull moving through head sea waves."
I Use ansys 14.5 on windows 8 with Visual Sudio 2012,
and are also installed Visual C++ 2005 2008 2010 (all x64)
The problem concerns the Compiled UDFs.
In the tutorial I provided the mesh, the source file (six_dof_property.c) and some case and data.
I put everything in a folder ( C:\Users\giuseppe\Desktop\ansys fluent ship motions)
I load fluent and follow the instructions.
3D, double precision and set the working directory:
C:\Users\giuseppe\Desktop\ansys fluent ship motions (the same of .c)
Read mesh
Set the models file (multiphase and viscous)
Define >> user-defined >> function >> compiled
In the source file add the .c file and build the libduf (defoult librery name)
In the same folder of .c is create the folder libduf
But in the Console messages me an error
Copied C:\Users\giuseppe\Desktop\ansys fluent ship motions/C:\Users\giuseppe\Desktop\ansys fluent ship motions\six_dof_property.c to libudf\src
udf_names.c file in 3ddp is upto date.
(system "copy "C:\Program Files\ANSYS Inc\v145\fluent"\fluent14.5.0\src\makefile_nt.udf "libudf\win64\3ddp\makefile" ")
1 file copiati.
(chdir "libudf")()
(chdir "win64\3ddp")()
"nmake" non Š riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
(("nmake" Š not recognized as an internal or external command,
operable program or batch file.))
Done.
And if load:
Opening library "C:\Users\giuseppe\Desktop\ansys fluent ship motions\libudf"...
Error: The UDF library you are trying to load (libudf) is not compiled for 3ddp on the current platform (win64).
Impossibile trovare il file specificato. ((Can not find the file specified.))
C:\Users\giuseppe\Desktop\ansys fluent ship motions\libudf\win64\3ddp\libudf.dll
Error Object: #f
Why?
where is the error ?
thank you
DartPeppe is offline   Reply With Quote
Old   September 13, 2013, 11:38
Rexxar
czhao86 is on a distinguished road
Did you try the SDK for compiling UDF?
andrei110726 likes this.
Best,
Rexxar
czhao86 is offline   Reply With Quote
Old   September 13, 2013, 12:52
Giuseppe Tescione
solution found!
I used VS2012 x64 cross tools command prompt for launch Fluent
is now in run calculation and it seems that is going well ... i tell you if there are problems ...
note: the windows software developement kit for windows8 is installed, probably SDK compiling automatically UDF if i start Fluent from VS command prompt...right?
thanks
Old   September 15, 2013, 01:01
Kai Ling
Hi, I am still very much stuck with my UDF code. Would really appreciate it if anybody could take a look at my attached c file and tell me what went wrong!
Old   June 16, 2014, 05:50
Default FLUENT UDF compilaton
andrei110726 is on a distinguished road
I am telling you follow these steps and very easy to set up
install MSVC 2010 Express edition
install windows sdk7.1
and load fluent from sdk command prompt by navigating to you file location
and type the casename.cas
it worked for me after spending 4 fucking days......
take care lads
andrei110726 is offline   Reply With Quote
Old   June 25, 2014, 10:52
Default well same problem as you guy
hannecart
Isitv2A is on a distinguished road
only two and a half day on it but still no solution ...
i install Visual studio 2010 than 2013 on my computer as well as SDK 7.0 .i run fluent from cmd shell and compiled but still this error :
The UDF library you are trying to load (libudf) is not compiled for 3d on the current platform (win64).
Le fichier spécifié est introuvable.
Isitv2A is offline   Reply With Quote
Old   August 4, 2017, 15:39
Default six dof property in UDF (ship hull simulation
Prasanna Ramanathan
Prasanna Ramanathan is on a distinguished road
hello,
can anyone send me the six_dof_property.c file mentioned in the ship hull tutorial for fluent.
thanks and regards,
Prasanna Ramanathan
Prasanna Ramanathan is offline   Reply With Quote
Old   January 5, 2019, 08:16
Tough Luck
nTTs is on a distinguished road
If anyone still has them, can I have the files needed for the heave tutorial please? My email is kinsasa04@gmail.com. Thank you in advance.
nTTs is offline   Reply With Quote
Old   May 26, 2021, 08:33
whkhor3 is on a distinguished road
Hi, Prasanna Ramanathan
Did you receive any reply regarding the six_dof_property.c file?
Mind sharing it?
Thanks
Regards,
whkhor3
whkhor3 is offline   Reply With Quote
(ask) how to create UDF for inlet velocity profile sincity Fluent UDF and Scheme Programming 83 May 16, 2022 14:04
UDF paraboloid velocity inlet rosco FLUENT 10 June 2, 2017 09:01
unsteady inlet velocity udf jill FLUENT 8 February 10, 2015 07:04
How to make a UDF to have a velocity profile in a square channel Gigis Fluent UDF and Scheme Programming 8 January 13, 2013 23:20
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
