modify gravity
Like Tree3Likes
  • 2 Post By pakk
  • 1 Post By silent2608
Old   April 2, 2013, 03:11
Default modify gravity
Sumit Tambe
Tamsu is on a distinguished road
I want to define x component of gravity as a sinusoidal function of time, how to do it?
Any UDF? what is Journal file and how do i use it here?
Or is there any way by which I can modify body force term in N-S equations?
Tamsu is offline   Reply With Quote
Old   April 2, 2013, 03:25
gearboy is on a distinguished road
You can use DEFINE_SOURCE to add your gravity momentum source(N/m3) into x momentum equation.
gearboy is offline   Reply With Quote
Old   April 2, 2013, 03:38
Sumit Tambe
[QUOTE=gearboy;417743]You can use DEFINE_SOURCE to add your gravity momentum source(N/m3) into x momentum equation.
Thanx a lot, got it. used CURRENT_TIME as time variable. UDF Manual also helped.
Old   November 5, 2014, 06:27
nspal1312 is on a distinguished road
I am facing same problem...
Can u tell me steps to follow?
Plz mail me udf for this
nirajpaliwal1312@gmail.com
nspal1312 is offline   Reply With Quote
Old   November 5, 2014, 06:40
pakk will become famous soon enough
Use CURRENT_TIME as time variable. UDF Manual can also help.
This will of course never happen. You can get help on writing your udf here, but I don't think a stranger will do all the work for you and mail it to you. I'd be surprised if these requests on message boards ever work.
stuart23 and Sun like this.
pakk is offline   Reply With Quote
Old   November 6, 2014, 07:36
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Quote Of The Day
stuart23 is offline   Reply With Quote
Old   January 30, 2016, 14:00
silent2608 is on a distinguished road
This thread is pretty old but since I found it through google I think others will, too.
I'm a Fluent / UDF beginner myself, but the following works for me. I verified results with manually using gravity in Fluent GUI. It works perfectly in my vof 2phase case. My UDF has a little bit different purpose but it's easy to adjust. Interpret UDF like always, go to cell zone conditions, select "Source Terms" and add it as x/y/z momentum however you like.
#include "udf.h"
DEFINE_SOURCE(gravity_source,c,t,dS,eqn)
real gravity;
real source;
real flow_time = RP_Get_Real("flow-time");
    if (flow_time < 0.1)
        gravity = 0.;
    else
        gravity = 9.81;
/* gravity*cr(ct) is gravity*density = N/m³ = specific weight = F(g) on a unit of volume of a fluid */
source = gravity*C_R(c,t);
return source;
In my case it simply activates gravity in +x direction after 0.1s flow time. If you need varying gravity just use a function for gravity instead of a constant. For example remove if / else and use flow_time in sine function for gravity.
BlnPhoenix likes this.
silent2608 is offline   Reply With Quote
Old   August 21, 2017, 03:02
Jayanta Barman
jbarman013 is on a distinguished road
#include "udf.h"
real gravity;
real source;
        gravity = 0.;
    else
        gravity = 9.81;
return source;
Hey, this didn't work for me. It shows an error that flow_time is an undeclared variable. Could you help me with that please?
jbarman013 is offline   Reply With Quote
body force, gravity, udf
UDF to modify gravity via M_gravity[ND_ND] or DEFINE_ADJUST jpo Fluent UDF and Scheme Programming 19 March 20, 2020 15:34
Modify gravity Tamsu FLUENT 0 April 2, 2013 03:08
UDF to modify gravity vector ? jpo Fluent UDF and Scheme Programming 3 January 24, 2012 10:10
