plasma actuator modeling udf code error
Like Tree5Likes
  • 3 Post By Alimohamadi_nasr
  • 1 Post By `e`
  • 1 Post By `e`
Old   March 27, 2013, 07:46
Question plasma actuator modeling udf code error
Won Joong Lee
ares0508 is on a distinguished road
Hello!
Now I just follow A.Bouchmal's MS thesis "Modeling of Dielectric-Barrier Discharge Actuator".
http://www.lr.tudelft.nl/fileadmin/Faculteit/LR/Organisatie/Afdelingen_en_Leerstoelen/Afdeling_AEWE/Aerodynamics/Contributor_Area/Secretary/Publications/publications/Msc_thesis_Adil_Bouchmal.pdf
However, the code which he atteched doesn't works.
I compiled the code and input conditions but when I start calculate, the error "FLUENT recieved fatal signal [ACCESS_VIOLATION] occurs.
My friend said that maybe the code is wrong.
Is there anyone who succeed to calculate this case?
Please help me to solve the problem.
ares0508 is offline   Reply With Quote
Old   March 27, 2013, 07:57
Ali Mohamadi
Alimohamadi_nasr is on a distinguished road
is there any udm in the code? if the answer is yes, did you determine the number of udm or not?
Alimohamadi_nasr is offline   Reply With Quote
Old   March 27, 2013, 08:59
Won Joong Lee
yes there are 5 UDM, but I determine the number of UDM 5.
Old   March 27, 2013, 09:15
Ali Mohamadi
in my case, the message appeared when I did not determine the number of udm, or for example I should define number of scalar in uds or otherr places. also, in my udf I should reset the udm in Demand, in this case also if i forget to do this it happens.
Old   March 27, 2013, 09:27
Won Joong Lee
Thanks to your reply.
but it still doens't works....
Old   May 14, 2013, 09:09
mahdi abdollahzadeh
mm.abdollahzadeh is on a distinguished road
Originally Posted by ares0508 View Post
Hello!
I have already runned that UDF and its working. U need to define two UDS also.
mm.abdollahzadeh is offline   Reply With Quote
Old   May 25, 2015, 06:18
Default Error
Siavash
Skabirian is on a distinguished road
Hello!
Hello my friend
I've tried this code too. but I have compile error. how can I fix that?
Skabirian is offline   Reply With Quote
Old   May 25, 2015, 20:39
`e`
`e` is on a distinguished road
A. Bouchmal has used User-Defined Memory (UDM) in his UDF. Ensure you have enabled a sufficient number of UDM slots because otherwise the solver will crash with ACCESS_VIOLATION as the memory is not available.
They have also used User-Defined Scalar transport equations (UDS) for the electric potential and net charge density. You will need to enable these UDS fields as well.
Skabirian likes this.
`e` is offline   Reply With Quote
Old   May 27, 2015, 10:41
Siavash
Thanks 'e'
what is the difference between them?
can you help me to run this code?
thanks
Old   May 28, 2015, 10:47
Siavash
This is the Error I faced:
The UDF library you are trying to load (libudf) is not compiled for 2d on the curent platform (win64).
The system cannot find the file specified.
c:\users\siavash\desktop\libudf\win64\2d\libudf.dl l
Old   May 29, 2015, 02:29
`e`
Originally Posted by Skabirian View Post
Thanks 'e'
thanks
UDS is for including another field scalar which is solved at each solver step and could include source terms. For example, they have used UDS for the electric potential and net charge density which are not usually included with the Fluent solver by default.
UDM is simply storing a value at every cell and is initialised with zero. For example, say you have an unsteady flow and want to visualise the locations where the local velocity exceeds some critical value. You could mark cells that exceed this critical velocity value and visualise these cells within Fluent as a contour plot as a function of your UDM. Without using UDM, you'd be left with the final solution and lose this intermediate velocity data at the end of each time step/iteration.
Have you read the threads on this forum for the same error? Ensure you're unloading and compiling your UDF properly, here are the steps I use.
toghay likes this.
Old   July 27, 2019, 02:31
mohammad karamzadeh
mohammad_karamzadeh is on a distinguished road
Hello
I need a video clip for Mr. Bochmal's udf configuration in the fluent. Please email me below. please help
mkaramzadeh151@gmail.com
mohammad_karamzadeh is offline   Reply With Quote
a.bouchmal, plasma actuator modeling, plasma modeling
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
