Can I change the diameter and density of Particles depend on the pressure using UDF |
January 13, 2013, 06:21 |
Yanlong Li
Rep Power: 13 |
Hi, bros:
I want to use DPM model to simulate the gas bubbles, but its density will changes depend on the pressure as well as its diameter. So How can I change it, I cannot found a Macros to do, does anybody have a better idear, Thank you. |
January 13, 2013, 06:49 |
SSL
Rep Power: 15 |
You should model it using eulerian approach
January 13, 2013, 11:46 |
Yanlong Li
Rep Power: 13 |
Thank you, msaeedsadeghi:
You mean using Miture Model? But I tried many times, it is very hard to converge after few iters. I think there was some error I can not mention. Do you know any place that I have to notice? |
DPM UDF Injection leads to 2 different particles | sega | Fluent UDF and Scheme Programming | 4 | December 28, 2017 23:57 |
forced to stick of soot particles | kmgraju | CFX | 9 | April 12, 2017 04:38 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Lagrangian particles (change density and diameter) | kel85uk | OpenFOAM | 1 | July 22, 2011 05:01 |
DPM - setting the density and diameter | Christian Svensson | FLUENT | 0 | February 14, 2003 14:44 |
