UDF for phase change
Like Tree4Likes
  • 1 Post By N400
  • 1 Post By N400
  • 1 Post By CFD Engineer
  • 1 Post By MDSHUJAN
Old   December 23, 2012, 21:46
Default UDF for phase change
nowbelle
N400 is on a distinguished road
I want to simulate the phase tranfer in the heat pipe, and a udf was compiled in FLUENT,which is as follow:
#include "udf.h"
#include "sg_mphase.h"
#define T_SAT 323
#define LAT_HT 2356e3
DEFINE_SOURCE(vap_src, cell, pri_th, dS, eqn)
Thread *mix_th, *sec_th;
real m_dot_v;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
/*m_dot_v=0.;*/
if(C_T(cell, mix_th)>=T_SAT)
m_dot_v = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT;
dS[eqn] = 0.;
if(C_T(cell, mix_th)<=T_SAT)
m_dot_v = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*fabs(T_SAT-C_T(cell,pri_th))/T_SAT;
dS[eqn] = -0.1*C_R(cell, pri_th)*fabs(C_T(cell, pri_th) - T_SAT)/T_SAT;
return m_dot_v ;
DEFINE_SOURCE(liq_src, cell, sec_th, dS, eqn)
Thread * mix_th, *pri_th;
real m_dot_l;
mix_th = THREAD_SUPER_THREAD(sec_th);
pri_th = THREAD_SUB_THREAD(mix_th, 0);
/*m_dot_l=0.;*/
m_dot_l = -0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT;
dS[eqn] = -0.1*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT;
m_dot_l = 0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*fabs(T_SAT-C_T(cell,pri_th))/T_SAT;
dS[eqn] =0.;
return m_dot_l;
DEFINE_SOURCE(enrg_src, cell, mix_th, dS, eqn)
Thread *pri_th, *sec_th;
real m_dot;
m_dot = -0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT;
dS[eqn] = -0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*LAT_HT/T_SAT;
m_dot = 0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*fabs(T_SAT-C_T(cell,pri_th))/T_SAT;
dS[eqn] = 0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*LAT_HT/T_SAT;
return LAT_HT*m_dot; }
Using the code above, I can simulate the evaporation, but the condensation did not appear, even the temperature of vapor was much lower than the saturation temperature.
Now I am so confused. Anyone can help me?
SACHIN1639 likes this.
N400 is offline   Reply With Quote
Old   December 24, 2012, 00:35
SSL
msaeedsadeghi is on a distinguished road
You may have not defined boundary conditions correctly. Please share files to check.
msaeedsadeghi is offline   Reply With Quote
Old   December 24, 2012, 01:09
nowbelle
My case and data files are bigger than the attachment allowing, may I send them to you via email?
My email address is nowbelle@yeah.net
Thank you !
PS:
Anyone else who is intersting in my problem or have the relevant experiences please contact me, we can communicate directly and quickly via emails! ^_^
sircorp likes this.
Old   December 24, 2012, 05:09
SSL
Yes. Please email me.
Old   December 24, 2012, 05:40
nowbelle
Thanks!
I just sent you the files via email, and l am looking forward your reply!
Old   April 19, 2013, 05:51
Shengchao Hu is on a distinguished road
Hi,N400
I am writing the udf for the phase change of LNG,i have some questions to share with you.Could you send me your files ?
Thanks very much! My email adress:shengchaohu2012@163.com
Shengchao Hu is offline   Reply With Quote
Old   November 18, 2013, 02:33
yangbin
yangbinsunshine is on a distinguished road
Hi,I am working on this udf recently.and I am confused about this sentence"m_dot_v = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT".
First,in this sentence,the coefficent is 0.1,but i do not know why.
Second,what is the unit of "m_dot_v"?
Thank you very much,and any advice will be highly appreciated.
yangbinsunshine is offline   Reply With Quote
Old   December 30, 2015, 00:28
Ram Kumar Pal
rampal is on a distinguished road
Dear friends,
I am doing the simulation of heat pipe in Fluent. I'm using udf for mass and energy source, but results are not coming specially condensation in condenser zone . All of you done this problem some times ago. I think you are more familiar with this problem. Please help me regarding this so can I complete my project work.
I will be very very thankful for your valuable help
rampal is offline   Reply With Quote
Old   December 30, 2015, 03:16
CFD Engineer is on a distinguished road
Did you got the new UDF with condensation. Please i need it can you send it to cfdengineer44@gmail.com.
Thank You
#include "udf.h"
#define T_SAT 323
real m_dot_v;
/*m_dot_v=0.;*/
dS[eqn] = 0.;
return m_dot_v ;
real m_dot_l;
/*m_dot_l=0.;*/
dS[eqn] =0.;
return m_dot_l;
real m_dot;
CFD Engineer is offline   Reply With Quote
Old   December 31, 2015, 01:15
Ram Kumar Pal
Dear friend, till now not successful to get results, as soon as result will came, I'll inform you.
Old   December 31, 2015, 01:48
Default Reg Hooking the UDF
  #11
Dear Friends,
i am using the UDF which you showed on cfdonline.com in the comment given by Mr nowbelle, it is good but i am confuse where to hook the UDF. I mean i had compiled it but which option should i selecte in Cell Zone condition and for which domain i have to define which part of the UDF. i tried giving udf_vap:: for vapour domain and udf_liq:: for liquid domain but it is showing error.
Old   June 15, 2016, 22:35
SHUJAN
MDSHUJAN is on a distinguished road
Hi N400. Did you complete your udf, and got condensation? I am working on a similar udf for simulating a heat pipe. Please can you send me your final udf at mdshujan@nevada.unr.edu
If condensation doesn't work, you can change the coefficient from 0.1 to other values, you can also try other condensation models instead of LEE Model.
Thanks and good luck
Chiara_riccio likes this.
MDSHUJAN is offline   Reply With Quote
Old   March 5, 2019, 06:34
jeet verma
jeet verma is on a distinguished road
hii i am working in same field and facing same problem can you please send me your udf at jeet.vrm18@gmail.com
jeet verma is offline   Reply With Quote
Old   March 5, 2019, 07:36
Ram Kumar Pal
I think, udf is not required. You can used evaporation condensation model under VOF multiphase model
Old   March 6, 2019, 01:47
jeet verma
thankyou for your reply sir, i am using the same evaporation and condensation model but in my case condensation in missing, fluent only evaporate the liquid and unable to condensate simultaniously.
Old   March 7, 2019, 01:44
Ram Kumar Pal
I think condensation should also happen, check once with fluent customer portal.
Old   March 12, 2019, 09:01
jeet verma
sir you were also faced similar type of problem as i see above, can you please tell me how you solve that problem.
thankyou
Old   March 13, 2019, 06:25
Ram Kumar Pal
thankyou
At that time, I tried to solve the issue but unfortunately could not find the reason of error. Contact once with fluent technical support for this. I have not found any article who have done evaporation condensation type problem by using evaporation condensation model of the fluent. Some people have done heat pipe and pulsating heat pipe problem by using udf on LEE MODEL, what I found is the evaporation condensation model is also based on LEE MODEL. I did not understand why evaporation condensation model of fluent is not solving the problem.
Presently I'm not doing this type of work, So I could not help you more. I'm sorry.
UDF Cmu change selçuk ataş FLUENT 2 July 19, 2017 13:24
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 07:46
UDF to change BC from Wall to Grid Line Aaron Smith FLUENT 0 February 21, 2006 10:14
Change Courant number from UDF HS FLUENT 0 December 1, 2005 06:16
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
