UDF for slip boundary condition
Like Tree3Likes
  • 1 Post By rasoulb
  • 2 Post By DaveD!
Old   December 10, 2012, 14:56
Smile UDF for slip boundary condition
rasoul b
rasoulb is on a distinguished road
Hi all
I have written a UDF for slip boundary condition (u_{s}=L_{s}*du_dy) by C_U_G(c,t)[1] Macro.
1- I test my UDF for 2 & 3D steady laminar channel flow, it's work good with low slip length (0.0001-0.005) but for larger slip length not converged. Can anyone guide me for this convergence problem?
2. I need to use velocity gradient of previous time step for unsteady simulation. what macros I should use?
thanks
BARKAT likes this.
rasoulb is offline   Reply With Quote
Old   December 10, 2012, 15:13
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Do you know that a boundary condition like this is already implemented in Fluent?
flotus1 is offline   Reply With Quote
Old   December 10, 2012, 15:29
rasoul b
what version? please guide me
Thanks
Old   December 10, 2012, 17:42
flotus1's Avatar
Alex
Last time i read about it was in the version 13 manual, but i think it can also be found in earlier versions.
I am out of office right now, so all I can do is recommend a google search with 'fluent high knudsen boundary'.
I think you will figure it out by yourself, otherwise feel free ask again.
Old   December 11, 2012, 03:46
rasoul b
slip velocity based on knudsen number is appropriate for gases and Not applicable for liquids. please say another method.
thanks
Old   December 11, 2012, 05:07
flotus1's Avatar
Alex
This holds true for a microscopic point of view.
But if you just want a boundary condition in the form (=*du_dy), the high Knudsen number boundary condition in fluent is the right choice, no matter what type of fluid you are using.
Old   December 13, 2012, 12:56
rasoul b
thanks flotus1 for your answers.
high Knudsen number boundary condition is for Low-Pressure Gas Systems and available only when the Laminar model is selected in the Viscous Model panel (based on explanation expressed in fluent 6.3 help). but my Model is LES and pressure is high in my case.
Old   December 14, 2012, 05:53
flotus1's Avatar
Alex
"high" pressure is not the problem in your case.
The boundary treatment can be used at any pressure level. The term "low pressure" comes from one of the applications of the model in low-pressure systems. But the model is appropriate at arbitrary pressure levels, whenever the Knudsen number is high.
I am currently studying flows at normal pressure levels with a BC like this.
But I see now that this BC is not an option since your Model is LES.
Perhaps it is possible to activate the BC with a LES model with a text command. This would be a question for the fluent support.
Old   November 13, 2014, 05:03
Default hi
Qureshi M Z I
m zahid is on a distinguished road
hi, i need a UDF for slip boundary condition at the bottom of the domain or at the ground (wall), case is just like a flow over a building. if anybody have sample UDF please share this, z is a vertical axis of my domain. thanks
mziqureshi@hotmail.com
regards,
m zahid is offline   Reply With Quote
Old   November 13, 2014, 05:12
pakk will become famous soon enough
regards,
Please read the messages in this thread more carefully. If you would have done that, you would not have asked for a UDF.
pakk is offline   Reply With Quote
Old   November 13, 2014, 09:42
Qureshi M Z I
hi, thanks pakk, here rasoulb use slip length instead of dynamic viscosity, as given in the link
http://www.cfd-online.com/Wiki/Wall_shear_stress
do u know the relationship between slip length and dynamic viscosity.
thanks
Old   November 13, 2014, 10:13
First question you should ask yourself: What is the equation for slip that you want to implement?
Second question you should ask yourself: What is the equation for slip that Fluent has implemented? (This is written in the Help, look it up.)
Third question: How can you choose parameters such that the Fluent implementation is the same as what you want?
Old   March 20, 2019, 11:37
Default UDF for slip boundary condition
  #13
DaveD! is on a distinguished road
Here is a code for applying a wall slip velocity based on wall slip layer thickness and the strain rate (which corresponds to \partial{u}/\partial{n}) at the wall.
To make it work, some under-relaxation is required for the calculated tangential wall velocity c_t.
BTW: The formula for Maxwell-based Slip Boundary Formulation for Low-Pressure Gas Systems (https://www.sharcnet.ca/Software/Flu...ug/node613.htm) is not applicable for cases, where there is a significant pressure and/or temperature change within the domain, since the parameter \lambda is auto-calculated by fluent. Hence, it is not possible to set \alpha_v and \sigma in way to get a constant factor left of the term (U_g-U_c)/\delta, which is an approximation for \partial{u}/\partial{n}.
Now, here is the code:
#include "udf.h"
Velocity slip at wall boundaries
separate routines for every velocity coordinate
UDF can be interpreted
at least 2 user-defined memories (UDM) need to be allocated first!
// wall slip layer thickness [m]
#define DELTA 10.0e-6
// under-relaxation factor for tangential wall velocity
#define RELAX_CT 0.1
DEFINE_PROFILE(slip_velocity_x,f_thread,index)
face_t face;
cell_t cell;
Thread *c_thread;
real u, v;
real ct, cx;
real gamma;
int i;
begin_f_loop(face,f_thread) // for each face: get face-id and thread
 cell=F_C0(face,f_thread); // get corresponding cell
 c_thread=THREAD_T0(f_thread); // get cell thread
 u = C_U(cell,c_thread); // F_U(face,f_thread); // get cell center velocity u
 v = C_V(cell,c_thread); // F_V(face,f_thread); // get cell center velocity v
 gamma = C_STRAIN_RATE_MAG(cell,c_thread); // get strain rate (equivalent to du/dn at wall)
 ct = (1-RELAX_CT)*F_UDMI(face,f_thread,0)+RELAX_CT*DELTA*gamma; // calculate tangential velocity (with under-relaxation using previous calculation step)
 F_UDMI(face,f_thread,0)=ct; //store in user-defined face memory (id=0) for next calculation
 cx = ct*u/sqrt(u*u+v*v); // component of ct in x-direction
 F_PROFILE(face,f_thread,index) = cx; // assign to profile
end_f_loop(face,f_thread)
DEFINE_PROFILE(slip_velocity_y,f_thread,index)
face_t face;
cell_t cell;
Thread *c_thread;
real u, v;
real ct, cy;
real gamma;
 cell=F_C0(face,f_thread); // get cell
 ct = (1-RELAX_CT)*F_UDMI(face,f_thread,1)+RELAX_CT*DELTA*gamma;
 F_UDMI(face,f_thread,1)=ct;
 cy = ct*v/sqrt(u*u+v*v);
 F_PROFILE(face,f_thread,index) = cy;
NonStopEagle and by1704116 like this.
DaveD! is offline   Reply With Quote
Old   May 3, 2020, 13:58
Default UDF for slip velocity and temperature jump
  #14
Homayoon sohrabi
homay95 is on a distinguished road
Hello everyone
I'm having problem with writing UDF for these two functions(slip velocity and temperature jump) below for a liquid-solid interface:
1. V= L(du/dy)
2. T)f = T)s + L(dT/dy)
in which V is slip velocity, u is mean velocity along with x axis, T)f is fluid temperature and T)s is solid temperature
I would appreciate very much if anyone who has UDF for those functions please send me here or at: homayoonsohrabi@yahoo.com
thanks for any help
homay95 is offline   Reply With Quote
Old   March 8, 2021, 05:35
Default UDF for slip flow in microchannels
  #15
FORGODSAKE is on a distinguished road
i want to add alternate slip and no slip boundary condition for studying fluid flow 2D microchannels . I wish to get slip length .what UDF should i use.
FORGODSAKE is offline   Reply With Quote
Old   October 15, 2021, 04:35
Xin Zhang
XinZhang is on a distinguished road
Hi, Dave. I read your UDF and I am working on a slip wall simulation too. The problem confuse me is that when we define the slip wall boundary, a Specified Shear sholud be defined in fluent. How can you write a UDF of the Shear Stress? Does your UDF work well now? Thanks a lot.
XinZhang is offline   Reply With Quote
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 11:18
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 22:54
UDF : boundary condition ID Flav FLUENT 4 June 28, 2001 10:52
