Merge topology?
Like Tree2Likes
  • 1 Post By n7310889
  • 1 Post By koskey
Old   August 13, 2012, 20:40
Default Merge topology?
n7310889
n7310889 is on a distinguished road
Could any of you please tell me what is the significance of the 'MERGE TOPOLOGY?" (YES/NO) in Ansys design modeller? I found it in "Extrusion option" of design modeller while I was extruding my multi body part. How does this "Merge Topology" concept differ from the "Merge Part" in multi body part?
Is it always necessary to form a single part, if my model contains different parts for different domains (say fluid and solid) or may be different cell zones? Because I found problem in meshing if I form a single part of my two body parts (that includes solid and fluid domains).
Furthermore, if I use "Sweep Mesh" method instead of "Multizone" method with specific sizing options for each domain (or zone) independently, is that okay? Because this method seems easier to me as I'm a beginner in Ansys. By this way, what I understand, the mesh would be patch independent at the (fluid solid) interface. Is there any problem if I make (fluid-solid) interface in the fluent after importing that mesh? Is there any option to make these mesh interfaces (between two cell zones) during the mesh generation in Ansys before importing it in the Fluent? If yes, then please let me know the procedure.
Thanks in advance to the prospective mentor.
n7310889
nepomnyi likes this.
n7310889 is offline   Reply With Quote
Old   October 3, 2012, 12:30
Nathan
koskey is on a distinguished road
Wish this got answered! I'm trying to troubleshoot why my mesh is not working correctly and have begun looking at everything from the start again
koskey is offline   Reply With Quote
Old   October 4, 2012, 00:26
n7310889
Hi, I didn't get any answer yet.
Old   October 4, 2012, 11:48
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
You have posted in the wrong forum. Try Ansys Meshing & Geometry
stuart23 is offline   Reply With Quote
attachDetach Topology Modifier: Proper Turbulent Boundary Conditions mturcios777 OpenFOAM Running, Solving & CFD 4 September 13, 2012 05:56
[ICEM] Merge mesh - non manifold vertices BrolY ANSYS Meshing & Geometry 4 October 30, 2010 23:07
assemble the mesh feixiangniao ANSYS Meshing & Geometry 2 March 20, 2010 03:39
ICEM topology Igor-a CFX 0 July 24, 2008 08:05
about merge mesh lian Main CFD Forum 3 February 29, 2008 11:47
