the DEFINE_MASS_TRANSFER is only a interpreting udf IN ANSYS 14.0 |
Fangdian
Rep Power: 14 ![]() |
HI
when i use the DEFINE_MASS_TRANSFER udf in ansys 14.0 . I compile the .c source file success ,then load it sucess as follows: ..... (chdir "libudf")() (chdir "ntx86\2ddp")() # Generating ud_io1.h test.c # Generating udf_names.c because of makefile test.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj test.obj Microsoft (R) Incremental Linker Version 10.00.30319.01 Copyright (C) Microsoft Corporation. All rights reserved. 正在创建库 libudf.lib 和对象 libudf.exp Done. Opening library "F:\rongdi\seconddimension\libudf"... Library "F:\rongdi\seconddimension\libudf\ntx86\2ddp\libud f.dll" opened cell_vis liq_gas_source Done. ..... But when i use the liq_gas_source in Multiphase Model dialog box , a error found in the messgage box: Error: NO user-defined function have been loaded Error object: #f when i use it with Interpreting UDFs, it is OK! on the other time, I use it with compile udf in the ansys 12.1. it is also ok! why? thanks! fangdian PS: my .c source file> #include "udf.h" DEFINE_PROPERTY(cell_vis,cell,thread) /*viscosity*/ {real ga_visy; real temp=C_T(cell,thread); if(temp<=1773) ga_visy=2; else if(temp<=1853) ga_visy=1e-3*(119.003-0.061*temp); else if(temp<=1873) ga_visy=1e-3*(10.603-0.0025*temp); else if(temp<=1973) ga_visy=1e-3*(36.263-0.0162*temp); else ga_visy=3e-3; return ga_visy; } DEFINE_MASS_TRANSFER(liq_gas_source,cell,thread,fr om_index,from_species_index,to_index,to_species_in dex) { real m_lg; real T_frost=1773; Thread *liq = THREAD_SUB_THREAD(thread, from_index); Thread *soild = THREAD_SUB_THREAD(thread, to_index); m_lg = 0.; if (C_T(cell, soild) >= T_frost) { m_lg = -0.1*C_VOF(cell,soild)*C_R(cell,soild)*fabs(C_T(cel l,soild)-T_frost)/T_frost; } if ((m_lg == 0. ) && (C_T(cell, liq) <= T_frost)) { m_lg = 0.1*C_VOF(cell,liq)*C_R(cell,liq)*fabs(T_frost-C_T(cell,liq))/T_frost; } return (m_lg); } |
SSL
I have asked Ansys Fluent support team. The problem is with the cracked version of fluent. In licensed version the compiled UDF can be easily selected in interaction menu.
Murdy Baskan
Rep Power: 13 ![]() |
i have same problem in mass transfer udf i solved using these formulas:
1)Do not make copy pastes because of character set of program it gives direct errors 2)Do not use thread pointer like this Thread *liq = THREAD_SUB_THREAD(thread, from_index); Thread *soild = THREAD_SUB_THREAD(thread, to_index); instead use thread pointer like this Thread *liq; liq = THREAD_SUB_THREAD(thread, from_index); Thread *soild; solid = THREAD_SUB_THREAD(thread, to_index); i have solved my problem using these tips. Have a good day. |
SSL
Are you running in licensed version of Fluent?
Our problem is that the compiled UDF can not be hooked in interaction menu. It says "No user-defined functions have been loaded", but I have really compiled and loaded it. I am highly professional in UDF writing but couldn't solve this problem yet. |
#5 | |
Sam
Rep Power: 16 ![]() |
Does anyone solve the problem? I have the same problem running in licensed version of Fluent. |
Max
Rep Power: 17 ![]() |
UDF-Manual 2.4.6. DEFINE_MASS_TRANSFER:
By default, FLUENT will attempt to hook mass transfer UDFs defined using DEFINE_LINEARIZED_MASS_TRANSFER. In order to hook a DEFINE_MASS_TRANSFER UDF to FLUENT, you must first issue the TUI command solve/set/expert and enter no at the Linearized Mass Transfer UDF? prompt. cheers |
#7 | |
Sam
Cheer
Rep Power: 0 ![]() |
I created a new .cs file in the VS, and saved it as x.c (C program file). Then I copied the udf code into the programming text frame and deleted some of the spaces in the udf (maybe actually they are not all real space). Amazingly, the x.c works.
I don't know which step is the key, but it can be a bit of help. |
define_mass_transfer |
Remeshing_ ANSYS 14.0_ System Coupling | acdesa | ANSYS | 4 | November 2, 2016 09:12 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 13:12 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | FLUENT | 0 | October 20, 2011 07:37 |
UDF Interpreting Error | stephen | Fluent UDF and Scheme Programming | 1 | May 8, 2010 01:10 |
Exporting results from CFX to ANSYS ?? | sohail ahmed | CFX | 1 | December 20, 2007 01:10 |
