How to deal latent heat during phase change through source term udf
Like Tree2Likes
  • 1 Post By yangbinsunshine
  • 1 Post By rampal
Old   April 21, 2012, 11:00
Default How to deal latent heat during phase change through source term udf
deepak
dkb_bg is on a distinguished road
Hi all
i have written udf for phase change from liquid to vapour in a narrow pipe.i think there is some problem with energy udf, since temperature is not decreasing but it should decrease.
DEFINE_SOURCE(enrg_src, cell, mix_th, dS, eqn)
Thread *pri_th;
Thread *sec_th;
real m_dot;
real P_SAT ;
real T_SAT;
P_SAT=exp(A+(B/(C_T(cell,mix_th)+C))+D*C_T(cell,mix_th)+E*log(C_T (cell,mix_th)))*1e5;
T_SAT= -P_SAT*P_SAT*2e-11+P_SAT*7e-5+254.1;
pri_th = THREAD_SUB_THREAD(mix_th, 0);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
if (C_P(cell, mix_th)<=P_SAT)
m_dot = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)*fabs(C_T(cell,pri_th) - T_SAT)/T_SAT;
dS[eqn] = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)/T_SAT;
else
m_dot = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(T_SAT-C_T(cell,pri_th))/T_SAT;
dS[eqn] = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)/T_SAT;
return LAT_HT*m_dot;
i am not very much clear with this udf. means due to phase change temp of liquid should drop.
plz enlighten me t will be grateful.
dkb_bg is offline   Reply With Quote
Old   November 14, 2013, 02:50
yangbin
yangbinsunshine is on a distinguished road
Originally Posted by dkb_bg View Post
Hi all
Thread *pri_th;
Thread *sec_th;
real m_dot;
real P_SAT ;
real T_SAT;
else
hi, i am very intrested ijn your problem.
i want to know how the coefficient 0.1 comes from?
is it suitable for every conditions?
SACHIN1639 likes this.
yangbinsunshine is offline   Reply With Quote
Old   November 18, 2013, 02:35
yangbin
Hi,I am working on this udf recently.and I am confused about this sentence"m_dot_v = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)*fabs(C_T(cell, sec_th) - T_SAT)/T_SAT".
First,in this sentence,the coefficent is 0.1,but i do not know why.
Second,what is the unit of "m_dot_v"?
Thank you very much,and any advice will be highly appreciated.
Old   January 8, 2016, 02:29
Default phase change problem inside heat pipe
Ram Kumar Pal
rampal is on a distinguished road
Dear friend, I'm doing the simulation of Heat pipe in FLUENT as my project work. I have written udf for mass and energy source for phase change inside the device. But condensation is not happening in condenser zone. If you have completed this problem, please help me.
SHUJAN likes this.
rampal is offline   Reply With Quote
Old   April 12, 2018, 21:26
England
chrischris is on a distinguished road
Same problem. How did you insert the udf ? Did you compile them ?
Could a VOF + EvaporationCondensation(Lee) model work without UDF ?
How about I just add an energy UDF on the water and vapor cell zone conditions ?
chrischris is offline   Reply With Quote
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
udf with moving heat source Ryan FLUENT 0 April 10, 2003 20:13
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
