March 2, 2024, 12:10 |
Mixing tank Set-up
David
Rep Power: 9 |
Hello everyone, I am doing the simulation of a mixing tank for industry purpose, however, I have multiple doubts about the setup.
The geometry is the following: TankGeometry.png The idea is to simulate the actual conditions of the tank which run at a velocity of 44 rpm and have 40-50% concentration in the bottom, 30-40% in the middle, and 0.1-2% in the top. I have the water mass flow inlet (3.6 kg/s), and the solid mass flow inlet (0.5 kg/s), however, I do not have any data on the inlet's geometries or outlet information, so I decided to do the simulation in a close system patching an initial volume which was about 27% of the total volume (corresponding to 40% concentration). TankInitialization.png Here I patched the particle's volume with a vof of 1, however, the packing limit was setup at 0.63. The set-up I used was an Euleria-Eulerian model, with a granular model active, the diameter particle was 100 um with a density of 1800 kg/m3, I chose the gidaspow and Lun-et al model for granular viscosity and bulk viscosity, respectively. I also use the gidaspow model in drag coefficient. The movement of the impeller where simulated using the MRF model. Gravity was activated and also turbulence was resolved using the K-epsilon model with dispersed turbulence multiphase model active. I first did a steady-state simulation using a simple solver and a pseudo transient solver, and both solutions were very different. I only drop residual to 1e-3, if residuals drop to 1e-5, the steady solution keeps changing. In the case of coupled the residual gets flat near 2e-3 for continuity and does not converge. SteadySimple.pngSteadycoupled.png Right now, I am doing a transient simulation using simple solver, i'm solving using an adaptive time scale with CFL of 1, but the maximum time step is 5e-4. This is the water counter after 20 seconds. TransientSimple.png So, my questions are:
Dye mixing inside a tank : UDS or Species Transport or DPM ? | Axel1 | FLUENT | 1 | March 17, 2024 01:45 |
Using gnuplot to plot probe data | Rotidpor | OpenFOAM | 3 | March 9, 2022 06:44 |
[ANSYS Meshing] Mixing tank hexahedral mesh (with zero thickness rushton blade) | Bil | ANSYS Meshing & Geometry | 0 | March 2, 2022 10:04 |
[surface handling] Decomposing Faces after Extrude2DMesh with autoPatch | JEBland | OpenFOAM Meshing & Mesh Conversion | 5 | December 6, 2021 08:28 |
Meshing industrial scale mixing tank | mlbontbs87 | FLUENT | 0 | April 26, 2011 16:18 |
