Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF, DPM model - particle penetrate phase interface issue!
Like Tree1Likes
  • 1 Post By dwoh12
Old   January 7, 2022, 04:45
Smile VOF, DPM model - particle penetrate phase interface issue!
dwoh
dwoh12 is on a distinguished road
issue
transient, VOF (water-air), DPM flow
inert particle in water flow penetrate water-air interface.
in an experiment, if particle density is closed to water, particles moves along the water flow streamline (velocity vector).
However, in the simulation, particle goes to air phase and move continuously...
simulation condition
flow condition
transient
volume of fluid (water, air)
implicit formulation
implicit body force
phase 1 : air (1.225 kg/m^3)
phase 2 : water (997 kg/m^3)
surface tension force modeling
surface tension : 0.072 [N/m]
continuum surface force - wall adhesion
viscous model (for turbulent)
k-epsilon (2eq)
realizable
scalable wall function
discrete phase (on)
interaction with continuous phase
unsteady particle tracking
inert - particle properties
denstiy : 1095.2 kg/m^3
injection type
normal to the inlet surface
randomize starting point
velocity : 0 m/s
boundary condition
inlet
water flow velocity : 0.03 m/s
water Volume fraction : 1
discrete phase BC type : reflect
wall
outlet
pressure-outlet
discrete phase BC type : escape
method
scheme : simple
presusre : PRESTO!
second order upwind (대부분)
initialization
compute from : inlet
patch to fluid region
velocity : 0 m/s
water Volume fraction : 0
before calculation, check through result contour (water phase 0, velocity 0 m/s)
run calculation
Jeffer likes this.
dwoh12 is offline   Reply With Quote
Old   May 20, 2022, 00:49
jefferson
Jeffer is on a distinguished road
Hi
Did you found the solution? I have the same proble, tha particles don't move with the water phase and I would like to know if you solve the problem
Jeffer is offline   Reply With Quote
interface, meniscus, multiphase particle
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari Fluent UDF and Scheme Programming 1 February 5, 2018 08:08
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
How to put melting point data of inert particle in DPM model of Fluent subhankar_bhandari FLUENT 0 July 28, 2010 08:40
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
