Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mesh size to simulate nanoparticles
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   May 20, 2020, 03:56
Default Mesh size to simulate nanoparticles
Abhishek Goel
abgoel363 is on a distinguished road
I am using fluent for the simulation of the reaction of supercritical water and metal salt solution in which metal oxide nanoparticles are forming.
How to decide the mesh size for the reactor of high pressure and high temperature (673K and 30 MPa)? should it be smaller than the particle size?
Thanks in advance for the help.
abgoel363 is offline   Reply With Quote
Old   May 20, 2020, 04:52
Default Nano-Partilces
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The only good approach to model nano-particles is to modify the properties of the fluid itself and do a single-phase simulation. People have tried using Lagrangian particle tracking but it is useless to do it that way since the particles are too small to affect the flow of the continuous fluid. It is only its thermal properties that are slightly affected by the nano-particles.
abgoel363 likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 20, 2020, 13:09
Abhishek Goel
Thank you very much for your reply.
Specifically, I am doing the simulation for continuous hydrothermal synthesis of metal oxide nanoparticles for ceria nanoparticles. (P=30 MPa, T= 673k).
I have already done the flow and thermal analysis by using realizable K-Epsilon model and reaction kinetics analysis by using volumetric species transport equation for the reaction in single phase.
Overall Reaction: 2Ce(NO3)3 + 4H2O --> 2CeO2(ceria)(aq.) + 6HNO3 + H2
CeO2 (aq.) --> CeO2 (solid)
My simulation consist of UDF for water properties at high pressure and high temperature and also for the rate of reaction as this reaction follows born type equation rather than Arrhenius rate.
Now I am interested to use population balance equation to get the particle size distribution of the ceria nanoparticle generated in reaction but this case is diverging whenever I use multiphase.
the reference for our work is
N. K. V. Nadimpalli, R. Bandyopadhyaya, and V. Runkana, A coupled CFD-PBM and thermodynamic analysis of continuous supercritical hydrothermal synthesis of nanoparticles, The Journal of Supercritical Fluids, vol. 136 (2018) 164–179.
-they have done the particle simulation for 2-dimensional reactor, but in our case, we have 3-dimensional reactor
Please give a comment on this how I can proceed.
Thank you very much in advance.
Old   May 20, 2020, 15:18
Default Nano-particle synthesis
vinerm's Avatar
Vinerm
This is not flow of nano-particles, rather its synthesis. You can do it using either PBM or Lagrangian but in both cases you have to write UDFs for nucleation, aggregation, coagulation, etc. Born type reactions rates are rather unstable but I doubt you have divergence because of that. PBM model requires proper setup and initialization. I'd suggest you to follow the guidelines for PBM setup and running as well as look for any tips the author might have given in the paper, if any. Or at least, follow their settings. 2D and 3D don't make a difference; it's just about an additional equation and geometric complexity. The physics remains the same.
Regards,
Vinerm
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 16:33
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
