Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Error at Node while running Calculation
Like Tree1Likes
  • 1 Post By vinerm
Old   April 30, 2020, 13:24
Post Error at Node while running Calculation
Raj
Rajkool is on a distinguished road
Hello all,
I got some unknown errors while calculating. I have attached the picture, you can find it in Console in the pic. Please let me know if you could help me?
Thank you in advance
Raj
Rajkool is offline   Reply With Quote
Old   April 30, 2020, 15:37
Default Ram
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The machine you are using does not seem to have enough RAM. Do not run in parallel because parallel simulation requires more RAM. Run in serial.
Rajkool likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 3, 2020, 19:05
Raj
It is the same model. I have run the simulation on the model before, now I am trying to play with the solution controls to get my solution.
I am operating it on the clusters (around 128GB RAM), but I don't know why I am facing this error.
Old   May 4, 2020, 17:19
Default Memory Issue
vinerm's Avatar
Vinerm
If it is a cluster then most likely you are not the only user; there might be other users using the machine at that time. The error you got is regarding less RAM. If you try it again and if there is enough RAM available, the case will run.
Regards,
Vinerm
error at node
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
Coal combustion, big node, slow calculation, parallel Whitebear CFX 1 April 8, 2014 04:27
Running MPI code on a multiprocessor node wen Main CFD Forum 7 April 19, 2006 17:35
Warning 097- AB Siemens 6 November 15, 2004 05:41
