Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Residuals Behaviour
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   April 28, 2020, 17:41
Post Residuals Behaviour
Raj
Rajkool is on a distinguished road
Hello all,
I am not familiar with CFD. I have applied some basic settings, boundary conditions, and started calculating.
The curves look like converging.
The question is, the starting point of the curve is not from "Zero".
Is it common or did I made anything wrong?
Any type of suggestion is highly appreciated.
Thank you
Raj
Rajkool is offline   Reply With Quote
Old   April 29, 2020, 12:09
Default Residuals
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Why do you expect residuals to start from 0? Ideally, it should be 0 when the case is converged. Practically, it is never 0 because the system is numerical and discrete.
Rajkool likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 30, 2020, 08:47
Raj
Can you give me some more information, if possible?
And is the my solution according to your reply?
Thank you
Raj
Old   April 30, 2020, 09:20
Default Residuals
vinerm's Avatar
Vinerm
The residuals look alright, as expected. However, the case setup may or may not be complete. First of all, flow most likely would be turbulence and you will have to enable a turbulence model. Secondly, you should always enable gravity for a multiphase case with appropriate values for operating density and reference pressure location. And it will take a lot of iterations, usually, 1000s for convergence.
Regards,
Vinerm
Old   April 30, 2020, 12:32
Raj
No, it is the laminar model. Yeah, I have given 1000 iterations. I just posted it while it was simulating. I am just confused about that, can I consider this convergence is correct or not?
Old   April 30, 2020, 12:42
Default Convergence
vinerm's Avatar
Vinerm
Residuals are not good for checking convergence. You should create a few monitors, such as, velocity at outlet, and/or pressure or volume fraction at outlet or in the domain. Once these monitors stop oscillating, then the solution should be considered converged.
Rajkool likes this.
Regards,
Vinerm
residuals, residuals fluent
Residuals show oscillating behaviour ! anon_l STAR-CCM+ 1 October 30, 2016 15:38
rhoSimpleFoam - strange behaviour of the residuals Werne OpenFOAM Running, Solving & CFD 2 December 16, 2014 05:27
Strange residuals behaviour xxxx Main CFD Forum 1 July 13, 2013 15:40
kOmegaSST omega residuals strange behaviour zordiack OpenFOAM Running, Solving & CFD 0 August 8, 2012 17:23
residuals behaviour on steady state simulations c120613 CFX 5 October 20, 2011 18:20
