Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
The references for Interfacial Area models
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   April 16, 2020, 13:06
Default The references for Interfacial Area models
Min Zhang
minzhang is on a distinguished road
Ansys/Fluent/Multiphase
Hello All,
I am using the Eulerian-Eulerian two-fluid model (in Ansys Fluent) to simulate the solid-liquid two-phase flow in a horizontal pipe.
This is the reference paper I am trying to reproduce:
Eulerian-Eulerian Simulation of Particle-Liquid Slurry Flow in Horizontal Pipe
Titus Ntow Ofei and Aidil Yunus Ismail
In "Multiphase Model - Phase Interaction - Interfacial area", it has the following models:
ia-particle
ia-gradient
ia-symmetric
ia-ishii
UDF
On this topic, the reference I found is here:
https://www.afs.enea.it/project/nept...terfacial-area
It talks about the Hibiki-Ishii model and the Ishii-Kim model, which I think is specific to bubbly flows in liquid, which is not my case here.
So I am wondering what are the models here?
Thanks!
minzhang is offline   Reply With Quote
Old   April 16, 2020, 14:03
Default The Reference
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The link you are referring to and the models you are talking about are completely different from each other. For a slurry, use ia-particle.
minzhang likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 16, 2020, 14:12
Min Zhang
Hello vinerm,
Thanks for your reply!
I am wondering whether you can direct me to the right place to know more about the Interfacial Area models in my case.
Old   April 16, 2020, 14:20
Default Reference
vinerm's Avatar
Vinerm
These are algebraic equations and are available at
https://ansyshelp.ansys.com/account/...area_conc.html
Regards,
Vinerm
Old   August 7, 2024, 16:47
Default same question but regarding Multiphase air water in centrifugal pump
Mohamed
faramm1j is on a distinguished road
hello, I have same question which of the menu I should choose but my case is multiphase air water in centrifugal pump
faramm1j is offline   Reply With Quote
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 10:46
Worse accuracy in LES models than in RANS models dferrando OpenFOAM Running, Solving & CFD 0 August 30, 2017 05:56
[OpenFOAM] Problem with cell area calculation in a slice daniel87 ParaView 5 October 24, 2015 17:18
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Storing Surface Area of each cell in a file? Markus Alzon FLUENT 0 June 21, 2007 09:38
