Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Missing Option on Display
Like Tree2Likes
  • 1 Post By Rajkool
  • 1 Post By vinerm
Old   March 10, 2020, 13:18
Post Missing Option on Display
Raj
Rajkool is on a distinguished road
Hello everyone,
I cannot see the plot option in the mass flow rate in fluent 2019 R2. Is it something wrong in the settings of Fluent R2 or it is default? Because I can find it in R3.
Thanks in advance.
Svetlana likes this.
Rajkool is offline   Reply With Quote
Old   March 11, 2020, 04:13
Default Plot
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You may define the plot separately under Report Plot.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 11, 2020, 07:22
Post Missing Plot Option
Raj
Yeah, I have searched for it. I am attaching the pics of ansys 2019 19.2, as you can see there is no option.
Once you by mistakenly close the window, then we should simulate again for the results as there is no plot option.
Is this common or there is any settings?
Last edited by Rajkool; March 11, 2020 at 07:23. Reason: Sorry, I forgot to upload images.
Old   March 11, 2020, 07:30
Default Plot
vinerm's Avatar
Vinerm
The plot is already defined. The options are just extra. With newer versions, plot is a separate entity. As you observe that it is defined under Report Plots. So, it already is a plot.
Regards,
Vinerm
Old   March 11, 2020, 08:16
Default Option to regenerate closed window
Raj
So, is there a way to regenerate the plot, once the window is closed by mistake after simulation?
Old   March 11, 2020, 08:33
Default Plot after simulation
vinerm's Avatar
Vinerm
If Fluent saved the data within data file, then you just need to run for 1 iteration and the plot will show. Usually, Fluent does not do that. Hence, if you did not write it out as an external file, plot is gone.
Rajkool likes this.
Regards,
Vinerm
Old   March 11, 2020, 10:11
Raj
Oh Okay. I'll try it.
Thank you Vinerm
Raj
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
