Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Discrete Random Walk Model yes or no
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   March 10, 2020, 11:46
Default Discrete Random Walk Model yes or no
MMatt
MMatt is on a distinguished road
I have simulated particles dissipation inside a room with both the DRWM enabled and disabled, and the results do vary a lot. In my case, it takes twice as much time with DRWM off for the particles to leave the room.
I struggle to see if I should be using DRWM in my case or not. What would be the reason(s) to use it? It is hard to understand if it should be applied to my case or not just reading the documentation.
MMatt is offline   Reply With Quote
Old   March 10, 2020, 11:59
Default Turbulent Dispersion
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If the particle size is comparable to eddy size then particle paths are affected by the eddies, hence, dispersion of particles due to turbulence becomes important and DRW or Cloud Tracking must be used. It will give higher accuracy in that case. If the conditions are not so then you should not use turbulent dispersion.
If the flow is highly nonhomogeneous and diffusion dominated, i.e., low Pe number, then DRW will give unphysical results, however, it does not mean that there is no turbulent dispersion of particles. Its just that DRW is not really valid and cloud tracking should be used.
MMatt likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 11, 2020, 03:33
MMatt
Thank you for your answer!
Am I right in saying that if I take the volume-average of K and E over the whole fluid domain, and use Kolmogorov formula for Fluent (https://www.cfd-online.com/Wiki/Turbulence_length_scale) I will get the eddy size (aka turbulent length scale)?
In that case the eddy size is huge compared to the particle size (eddy size 75mm particle size under 1um).
Old   March 11, 2020, 04:09
Default Eddy length scale and particle size
vinerm's Avatar
Vinerm
Volume averaged value for eddy length scale or any field related to turbulence is not a good indicator of turbulence. So, you have to plot the eddy scale contours. Furthermore, if you include minimum three tries for DRW, then the particle tracks with and without DRW should be of similar order. However, if the particles in your domain are of submicron size, then you can certainly neglect the effect of turbulence. Such small particles usually have no drift velocity and go with the mean flow.
MMatt likes this.
Regards,
Vinerm
Fluent Limitations tymcme FLUENT 6 August 1, 2022 09:50
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
A Query on Dense Discrete Phase Model - Transition Factor shashwatb Fluent Multiphase 0 June 16, 2015 10:55
Discrete Phase model hari_ls FLUENT 2 December 4, 2010 07:30
