Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Velocity Profile Obstruction and Velocity Profile Distribution
Like Tree1Likes
  • 1 Post By vinerm
Old   March 9, 2020, 11:47
Default Velocity Profile Obstruction and Velocity Profile Distribution
Raj
Rajkool is on a distinguished road
Hello everyone,
Sorry for the poor title. I could not find the best name .
So, I just want to give an overview of my model. I have multiple inlets and multiple outlets. One inlet consists of one type of fluid and all others have one type of fluid. They both mix and flow through multiple outlets.
At present, I'm testing with a single fluid in all inlets to understand the flow of the fluid. But, I find some obstruction of the fluid in one inlet and flow at the outlets are not at the center of the model.
Please any type of help or suggestion would be highly appreciated. Please let me know for further info!
Thank you
Raj
Rajkool is offline   Reply With Quote
Old   March 9, 2020, 14:57
Default Centrally peaked profile
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Is there any particular reason to expect that flow should be more towards the center? With multiple inlets and outlets, flow could take almost any profile through any of the outlets.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 10, 2020, 07:11
Raj
Yeah, there is a reason behind expecting the flow at the center i.e, they are mixed and formed as a single flow in the next step. So, we need a concentric flow of multiple outlets for uniformity.
Old   March 10, 2020, 08:51
Default System Design
vinerm's Avatar
Vinerm
The fluids might mix, however, on its own, the device cannot deliver uniformly distributed flow. It has to be designed to deliver a uniform flow, within a certain distribution error.
Regards,
Vinerm
Old   March 10, 2020, 10:20
Raj
you mean, it can only be done only by modifying the design?
Old   March 10, 2020, 10:40
Default Design
vinerm's Avatar
Vinerm
Even if you provide very uniform inlet flow and there is only one fluid, outlet will not be uniform until and unless the device is designed to do that.
Rajkool likes this.
Regards,
Vinerm
Old   March 10, 2020, 11:16
Post Multiphase flow
Raj
If I change the settings from the single phase to the multiphase model(VOF), will it help?
Old   March 10, 2020, 11:20
Default Help in what sense
vinerm's Avatar
Vinerm
Changing from single phase to multiphase will show the results as per multiphase. It will be closer to reality if it is supposed to handle two immiscible fluids in reality. But will it improve the homogeneity, can't say. It may make it homogeneous or even more non-homogeneous. Its the job of turbulence to make it homogeneous. Higher the turbulence, better the homogeneity.
Regards,
Vinerm
Old   March 10, 2020, 11:39
Raj
I'm sorry. I forgot to mention. In my model, the flow is laminar.
Old   March 10, 2020, 11:45
Default Homogeneity and Laminar Flow
vinerm's Avatar
Vinerm
Laminar flow is never homogeneous, even on the top of a flat plate or through a simple duct.
Regards,
Vinerm
Old   March 10, 2020, 13:22
Raj
oh okay. Thank you for the information. I will just look for more info.
Thank you for the time
Question Regarding to Export and Import The Velocity Profile John Lee STAR-CCM+ 4 September 19, 2014 10:01
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 19:42
