January 31, 2020, 03:41 |
Issue with particles speed/definition
MMatt
Rep Power: 13 |
Hi all (again),
I am still new to multiphasing simulations with particles and I face a weird issue with my multiphase particles simulation in fluent. The issue is that the residuals for the second phase (the particles) stays at 0 (u, v, w, vf). However, when I plot the particles velocity in a particular axis, they have a velocity in the different axes. When I check the secondary phase material, the only option I can set is air (the granular option is checked). Not sure this is normal, or if I should have to select some kind of solid material for this second phase. The particles in my model are considered inert, but not massless. Why does the residuals for the second phase stay at 0? And on a side note, is there a way to get the number of particles in a cell zone? Thanks! |
January 31, 2020, 04:27 |
Ambiguity
It appears that you have both, DPM as well as Euler model, enabled in your simulation. This is required only if particle phase occupies rather high volume fraction, say more than 15%. Otherwise, you do not need to enabled any (Eulerian) multiphase model. Keep that off.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
January 31, 2020, 04:36 |
MMatt
Rep Power: 13 |
Thank you so much for all your help, I really appreciate it! Never expected to get replies to my messages, and even if I did, I wouldn't have expected anyone helping so quick. So thank you once again!
Particles are not hitting the wall | CedricVH | OpenFOAM Bugs | 23 | May 19, 2016 21:29 |
Add lagrangian particles to OpenFoam solver | luchen2408 | OpenFOAM | 0 | June 2, 2015 04:10 |
[OpenFOAM] plot particles and animation in paraview | phsieh2005 | ParaView | 1 | July 26, 2013 06:35 |
Particles do not hit the wall | CedricVH | OpenFOAM | 0 | April 15, 2010 09:21 |
particles model | ati_ros61 | FLOW-3D | 3 | December 6, 2009 17:03 |
