Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Boundaries conditions in Fluent
Like Tree1Likes
  • 1 Post By MKuhn
Old   March 7, 2019, 15:37
Default Boundaries conditions in Fluent
Manel
Manel is on a distinguished road
Hello everyone 🤗
Can you respond me these questions freinds ?
1. Can we set both velocity and pressure conditions at BC?
For example : the inlet .
2. How can we set operating pressure for a liquid flow?
3. What is the difference between :
Reference pressure / operating pressure/ total pressure/
Jauge pressure in fluent?
4.how can we set reference pressure in reference values ?
I have got a false result for a jet into cavity filled usually by air.
I think my BC are false because my confusion about pressure.
Thanks you very much.
Bye
Manel is offline   Reply With Quote
Old   March 11, 2019, 05:45
Moritz Kuhn
MKuhn is on a distinguished road
1. For one boundary you can not set both for one inlet. It would be overdetermined.
2. "Setting Up Physics" --> "Operating Conditions" --> "Operating Pressure". This should be the pressure in you cavity. If you have atmospheric presse in your cavity, leave it by default 101325 Pa.
3. Gauge Pressure is difference to the Operating Pressure. Total Pressure = Static + Dynamic pressure and Absolute Pressure = Static + Operatin. For a pipe flow with pressure inlet and pressure outlet. Set pressure outlet to Gauge Pressure = 0 and and the value for pressure inlet to a value greater than 0 (which is the pressure drop of you pipe).
The reference pressure is used only for postprocessing, to compute the pressure-related forces and moments and the pressure coefficient.
khaledhmz likes this.
MKuhn is offline   Reply With Quote
Old   March 12, 2019, 06:28
Manel
Good morning,
Thanks you very much .
Nice day.
Manel
[ANSYS Meshing] Ansys fluent periodic boundary conditions and mesh DanieleDeRossi ANSYS Meshing & Geometry 0 April 22, 2018 15:36
[ICEM] Boundary conditions problem in ICEM and Fluent Far ANSYS Meshing & Geometry 6 September 10, 2014 20:48
Fluent doesn`t recognice boundary conditions chriskit FLUENT 7 June 27, 2012 09:12
Gridgen's boundary conditions and Fluent famarcfd FLUENT 0 December 12, 2009 11:00
Fluent accuracy and boundary conditions Paolo Lampitella FLUENT 0 June 12, 2008 07:25
