December 10, 2018, 16:56 |
evaporation-condensation vof duct
Rep Power: 8 |
I am trying to simulate air-water flow through a parallel plate. My simulation is 2d. both phases enter through the same side. the length is 2m and the width is 20 mm which, at the first, the water width is 7 mm. there are mass transfer and heat transfer between them. the water temperature is 50 degree and air temperature is 20. the interface between water and air changes. Firstly, what if I want to change mesh by recognition of the interface, should I use sliding mesh or dynamic mesh and how? Secondly, for evaporation and condensation, can I use evaporation-condensation of fluent? or because the temperature is lower than the saturation temperature I cannot use this option? Thank you in advance. |
December 11, 2018, 08:30 |
Yes you can use evaporation condensation lee model to simulate the mass transfer
I prefer to use 3d however 2d it is simpler and faster You should use one zone and patch the water region by adapting tool |
December 11, 2018, 16:09 |
#3 | |
Rep Power: 8 |
Do you have any idea about evaporation and condensation factor? |
dynamic mesh;, evaporation condensation, multiphase flow, vof model |
Evaporation and condensation model in VOF | ic3lemon | Fluent Multiphase | 0 | December 12, 2015 07:56 |
Evaporation and condensation Model in Fluent | amy24d | Fluent Multiphase | 5 | May 26, 2015 13:20 |
VOF with evaporation and condensation UDF's | gerardosrez | Fluent Multiphase | 4 | March 15, 2015 16:01 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 21:47 |
evaporation and condensation in the VOF model | Glev | FLUENT | 0 | December 24, 2004 05:55 |
