Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian eulerian solid liquid flow
Like Tree1Likes
  • 1 Post By souza.emer
Old   August 26, 2018, 03:59
Default Eulerian eulerian solid liquid flow
Payam
Payamsz is on a distinguished road
Dear All.
I am simulating steady state solid liquid flow in eccentric horizontal annulus with eulerian grannular multiphase model.
when the volume fraction of solid recieve to packing limit , omega in k-w or ebsilon in k-e model make the solution un stable.
I use no slip wall , free slip wall and specularity coeficient for solid particle on the wall, but my problem didnt solve.
this problem apear when I use gidaspow grannular viscosity.
please help me, I have stuck this problem for three mounth.
drag model: gidaspow
lift model: saffman mai
I use per phase, mixture and dispered phase and test every turbulance model, I chek the grid.
the total length of annulus is 10 m.
inlet volume fraction 1 %.
inlet velocity 1.5 m/s.
inner wall is rotating wall with 60 rpm
Payamsz is offline   Reply With Quote
Old   August 30, 2018, 10:02
Emerson
souza.emer is on a distinguished road
Hello Payamsz
There are some pieces of advice in the Ansys advanced course for multiphase flow. Have you checked that to see if your case is ok with the recommended set up? If you want the file please give your email address. I'm working with a flow that I have to use the patch my particles volume fraction.
Payamsz likes this.
souza.emer is offline   Reply With Quote
Old   August 30, 2018, 19:20
Payam
Originally Posted by souza.emer View Post
Hello Payamsz
Thank you. payamsc@gmail.com
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Zero velocity of liquid at outlet in stratified flow using interFoam mike.franky OpenFOAM Running, Solving & CFD 0 May 9, 2018 11:16
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Multiphase flow (Eulerian) modeling Umesh FLUENT 5 December 29, 2014 11:06
Solid fraction proflie about Eulerian model wangjihong0407 FLUENT 3 July 17, 2011 16:27
