How to introduce mixture of air and oil in fluent |
Swaroop
Rep Power: 8 ![]() |
I am simulating in fluent to see the coolant effect on tool used in turning operation. I don't know how to introduce mixture of air and oil in the fluent. Can anyone guide me ? It would be of great help.
Thanks in advance. |
Maitray sharma
Rep Power: 9 ![]() |
Hey mate, the description is very limited , but this is how you should approach, use eulerian 2 volume of fluid method,specify what are the phases, for eg phase 1 oil and phase 2 = air or vice versa. and in the phase interaction, use any one surface tension model (not sure) , and the challenging part is the solution initialisation , for that i need further info regarding the geometry, i hope it helped.
Swaroop
Thank you very much. Here is the geometry of the part. There is a small surface you can see at the edge. It is the tool tip and it is where I am giving 1090 kelvin as temperature.
I am posing links for the geometry for your better understanding. https://drive.google.com/open?id=1oA...9vEhWBUjmHkLAu https://drive.google.com/open?id=1U7...iDsoD6nvzcxlCA https://drive.google.com/open?id=1qe...qMEfkAzM6O0Nhz |
Maitray sharma
If it is a steady flow, it doesn’t matter at all whatever fluid you are using regarding this simulation since i am assuming you are using fixed temperature boundary, moreover if you are using transient , and if i assume that there is a pipe flow from where the oil is coming ( most common) , then you need euler multiphase volume of fluid method, i hope it helped.
Swaroop
Ok. Thank you.
kiarash
hi everyone i am working on a multiphase fluid simulation in fluent . that is pipe that have a saturated vapor with a cooled wall . after simulation with a acceptable residuals and the temperature contours was good but about volume of fraction of each phase there is no good results and all fluid domain have a constant volume fraction . indeed i wanna calculate amount of condensed liquid . is there anyone can help me ? its so necessary for me ...
and also i m sorry of my bad english :| here is my email : kiarashniroumand@gmail.com |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 03:53 |
Implementing the Black Oil Model In Fluent ??? :confused: | Abhya | FLUENT | 2 | November 12, 2012 04:59 |
oil aeration problem | wprostaff | FLUENT | 0 | July 19, 2011 16:41 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
multiphase oil air separator tips | matt giuli | CFX | 1 | October 6, 2008 23:50 |
