Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
steady-state and Convergence
Like Tree1Likes
  • 1 Post By Thromkar
Old   July 14, 2018, 06:01
Default steady-state and Convergence
Yoser
yoser is on a distinguished road
Hi all
I am working on 3D simulation for my project. The solution already convergence. How can check if the solutions reached steady-state after the specified residual drops?
yoser is offline   Reply With Quote
Old   July 24, 2018, 04:44
Thromkar is on a distinguished road
Originally Posted by yoser View Post
Hi all
Hello Yoser,
at first describe your problem in detail.
You can only be sure that you reached a steady-state status if you monitor some output variables, which are interesting for you. For example the pressure drop or the velocity- and temperaturefield (if you are using ernergy equations).
In the newer Versions of Fluent you can define your own convergence criteria.
I am, for example, simulating heat transfer over plates. I check convergence by calculating the residuals of the volumeintegrals for temperature in both of my fluid and in my solid domain. In addition i check convergence of the pressure volume integral.
Check the Ansys help for additional information:
"28.15.1.3. Overview of Using the Residual Monitors Dialog Box"
yoser likes this.
Thromkar is offline   Reply With Quote
Old   July 24, 2018, 16:22
Yoser
Thank you so much Thromkar
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Convergence in steady state simulations vs transient ones cardioCFD CFX 5 January 21, 2018 11:59
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 05:59
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
