Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
URF vs Time Step Size
Like Tree2Likes
  • 2 Post By BlnPhoenix
Old   February 20, 2018, 00:58
Default URF vs Time Step Size
Ahmed Alkaisi's Avatar
Ahmed Alkaisi
Ahmed Alkaisi is on a distinguished road
Send a message via Skype™ to Ahmed Alkaisi
What is better to achieve the convergence?
Lowering URF or reducing Time step size?
Thanks
Ahmed Alkaisi is offline   Reply With Quote
Old   March 6, 2018, 05:40
BlnPhoenix is on a distinguished road
Originally Posted by Ahmed Alkaisi View Post
Thanks
In general, i would only touch URF if the solution is diverging.
BlnPhoenix is offline   Reply With Quote
Old   March 10, 2018, 00:36
Ahmed Alkaisi
Thanks for replying
But don't you think reducing time step has a bigger effect on solution than URF?
and what is the lowest value of URF you can use?
Regards
Old   March 10, 2018, 06:11
Thanks for replying
Regards
To be honest i can not give you a good answer to when to prefer a lower URF instead of a lower time step, since i never faced such a situation. But my guess is, if lowering the time step again and again doesn't not help at all, i would look into lowering the URF for a given time step size. There is then probably a optimum (calculation time wise) of time step and URF when you have a difficult problem that is not easy to stabilize.
Theoretically speaking the lowest URF would be something very small but > 0.
Old   March 19, 2018, 01:00
Ahmed Alkaisi
Thank you for your reply
Old   March 19, 2018, 12:00
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Isn't URF somehow related to the Courant number as well. If that is the case then URF will effect courant number, likewise, time-step also effects courant number. Hence, stability of the problem would depend on URF and time-step size!!
hamed.majeed is offline   Reply With Quote
Old   March 20, 2018, 08:18
I'm not aware of any such relation. Can you give a source for this?
Regards
Old   March 20, 2018, 09:30
Hamed Abdul Majeed
In Fluent theory guide (V19)>21.4.4 Steady-state iterative algorithm>21.4.4.2 Under-relaxation of equation.
The CFL is a solution parameter in the pressure-based coupled algorithm and can be written in terms of \alpha:
(1-\alpha)/\alpha=1/CFL
Under-relaxation factor=\alpha
Old   March 20, 2018, 09:43
I don't understand this. I know the CFL definition only for time dependent simulations, here it is used for steady state applications. Also URF = 1 is commonly used in transient simulations for certain equations. The given formula here however yields CFL = 0 for \alpha = 1.
So maybe this is an alternative usage/definition of CFL, which in turn i don't see a use for in multiphase flows since these are pretty much always transient..
But thanks for making aware of this!
Last edited by BlnPhoenix; March 20, 2018 at 09:53. Reason: Correction of equation.
Old   March 23, 2018, 10:39
Hamed Abdul Majeed
The definition I told you is for implicit relaxation of equations.
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
