Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multi Fluid Eulerian Model: defining secondary phase
Like Tree2Likes
  • 1 Post By weihong
  • 1 Post By bhargavbharathan
Old   July 14, 2017, 11:45
Default Multi Fluid Eulerian Model: defining secondary phase
weihong is on a distinguished road
Dear all, I am a beginner with ANSYS Fluent and multiphase modelling. I encountered a problem while defining the problem using Multifluid Eulerian model, I must set the secondary phase as fluid as mentioned in the tutorial.
"For a granular phase (which must be placed in the fluid materials category, as mentioned in Steps for Using a Multiphase Model), you need to specify only the density; you can ignore the values for the other properties, since they will not be used."
However, when I define the secondary phase as fluid, I am unable to set the appropriate drag force model because it is treated as fluid-fluid instead of fluid-solid, i.e. drag models of Syamlal-O’Brien, Gidaspow, Wen-Yu does not show up.
This definitely seems contradictory to me so I’m not sure if I missed out anything in the procedure. Thanks all for your time!
Amall aliraqi likes this.
weihong is offline   Reply With Quote
Old   July 18, 2017, 13:24
Bhargav Bharathan
bhargavbharathan is on a distinguished road
Did you try assigning the secondary phase as "granular" under phases->secondary phase. This should open up the drag law options you are looking for.
-BB
bhargavbharathan is offline   Reply With Quote
eulerian-granular, fluid-solid, multiphase
buoyancy force of second phase in Eulerian model amin.z FLUENT 5 March 14, 2015 02:40
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Eulerian Multi Fluid Model CFDtoy Main CFD Forum 3 January 25, 2005 14:44
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
