May 27, 2017, 06:37 |
Droplet generation
Rep Power: 9 |
Hei guys..
Can anyone please kindly tell me how to simulate a droplet generation in multiphase model? The system is a continuos liquid water flows into nozzle then exit as water droplet. I do really appreciate your help |
June 1, 2017, 05:00 |
Rep Power: 14 |
You can try VOF model. Keep in mind that you need a sufficient mesh resolution to capture the droplet interface. What is your second phase, air?
June 3, 2017, 23:21 |
Rep Power: 9 |
thank you for replying BlnPhoenix ,
I've tried using VOF and yes the second phase is air, but the flow is still continuous. My geometry is quite big, I am using unstructured mesh and the sizing is 0.01 m, is it not sufficient? If not, can you tell me how small it should be? |
June 4, 2017, 01:47 |
#4 | |
Quang Le Dang
Rep Power: 14 |
June 4, 2017, 03:33 |
Rep Power: 9 |
Does it mean that eulerian model can only model the bubble flow? not the droplet? and what will happens if the volume fraction of the liquid is much less than the air?
June 4, 2017, 03:38 |
#6 | |
Quang Le Dang
Rep Power: 14 |
Sent from my SM-A520F using CFD Online Forum mobile app |
June 4, 2017, 05:23 |
Rep Power: 14 |
You could use Multi-Fluid VOF Model in Ansys, which is a hybrid Eulerian-VOF Model. Based on your mesh size it captures the (very) large Droplets of water as VOF, the rest is dispersed Eulerian fraction for which the mesh resolution is not sufficiently small enough.
If you want to model all the detail (interfaces of small, medium droplets) there is unfortunatly no alternative to decrease in mesh size. You will see gradually more detail with every step of mesh refinement with the VOF approach. |
June 5, 2017, 10:30 |
#8 | |
Rep Power: 9 |
alternate droplet generation in double t channel using ansys fluent | hariswch2 | ANSYS | 0 | January 22, 2014 02:06 |
Droplet Generation | Isahi Patil | Main CFD Forum | 0 | August 4, 2006 06:11 |
Droplet Generation | nic | FLUENT | 2 | February 23, 2005 15:45 |
Droplet Generation | nic | Main CFD Forum | 1 | February 22, 2005 13:51 |
Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 05:07 |
