Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Formation of thin film
Like Tree1Likes
  • 1 Post By Saiee
Old   May 19, 2017, 02:20
Default Formation of thin film
Sayali Chavan
Saiee is on a distinguished road
We are simulating formation of thin film on flat plate. It is a case of Liquid Desiccant dehumidifier. The desiccant solution is flowing from upper-left corner and moist air is flowing in counter-current direction (Please see schematic diagram). Here VOF formulation is used with implicit body force (gravity and surface tension force are active). Along with VOF, k-epsilon model, Energy equation, CSF (with wall adhesion) is used.
SIMPLE for pressure-velocity coupling, PRESTO! for pressure interpolation and First Order Upwind scheme for momentum and turbulence equations are used. And mesh is structured.
Problem: Liquid stops flowing when air velocity is increased beyond 5 m/s (which is not acceptable according to literature).
liquid velocity: 0.028 m/s
air velocity: 5 m/s
Please help us out with this problem.
Thank you.
Ahmed Alkaisi likes this.
Saiee is offline   Reply With Quote
Old   May 19, 2017, 07:24
Ahmed Alkaisi's Avatar
Ahmed Alkaisi
Ahmed Alkaisi is on a distinguished road
Send a message via Skype™ to Ahmed Alkaisi
air velocity: 5 m/s
Thank you.
Please you help me
I'm doing similar thing
Evaporation-condensation
But I can't capture the condensation film
No condensation
Even I can't intialize Eulieran wall film!
Anyone help please
Sent from my SM-G900I using CFD Online Forum mobile app
Ahmed Alkaisi is offline   Reply With Quote
Old   May 19, 2017, 11:01
Sayali Chavan
Dear Mr Ahmed,
My problem is different. There is no Evaporation or condensation involved.
But, I can suggest you few things.
1) Check if your mesh is fine at the boundary (where Film is supposed to form)
2) Check boundary conditions.
Please elaborate the problem. So that we can have some insight.
Thank you.
Error in thin film formation Andrew_Sm OpenFOAM Running, Solving & CFD 1 July 5, 2016 06:35
Evaporation of thin water film Stephen Waite CFX 6 July 3, 2014 23:14
VOF - Eliminating shear on the surface of a thin liquid film saisanthoshm88 Fluent Multiphase 0 October 27, 2013 13:22
Simulating Heat transfer in Two-Component internal mist cooling with thin film AdarshGouda FLUENT 0 March 12, 2013 18:18
Reversed flow error with thin film heater MK FLUENT 1 February 12, 2009 11:26
