Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Evaporative phase change modeling in FLUENT
Like Tree1Likes
  • 1 Post By Kimia
Old   March 30, 2017, 15:23
Default Evaporative phase change modeling in FLUENT
Kimia is on a distinguished road
Hi all,
I am working on a micro scale simulation of evaporation inside a porous structure, using ANSYS FLUENT. It is a transient two phase model (VOF) considering water and vapor inside a micro scale pore. I am using UDF codes to apply the source terms relative to the mass transfer according to Schrage's model formulation.
The results that I get seem to be logical, but my problem is that the time steps that I have to use are very small ( in the order of ~1e-9 s), which make it impossible to reach convergence.
Every time I increase the time step, I face the error that the "Global Courant number is greater than 250.00. The velocity field is diverging. check the solution and reduce the time step".
I really appreciate it if you have any suggestions or solutions for this problem or you have any recommendations for me to increase the time steps to more realistic values.
Ahmed Alkaisi likes this.
Kimia is offline   Reply With Quote
Old   March 31, 2017, 05:36
Ahmed Alkaisi's Avatar
Ahmed Alkaisi
Ahmed Alkaisi is on a distinguished road
Send a message via Skype™ to Ahmed Alkaisi
Decrease URF to (0.2-0.5)
Use implicit
Sent from my SM-G900I using CFD Online Forum mobile app
Ahmed Alkaisi is offline   Reply With Quote
Old   May 12, 2017, 00:39
Hao su
blue-sky is on a distinguished road
Originally Posted by Kimia View Post
Hi all,
hi,I'm working on boiling flow inside a tube, and I meet the same problem with you. Can you have some new ways to solve this problem? And i meet other problems that the bobble couldn't separate from the wall. can you give me some advice. thank you very much
blue-sky is offline   Reply With Quote
Old   May 12, 2017, 07:53
David Chou
hospital0968 is on a distinguished road
Courant number = v*dt/dx
if C is huge enough to lead to divergence, decrease dt or increase dx
hope this will help
hospital0968 is offline   Reply With Quote
Old   May 13, 2017, 02:43
Hao su
hope this will help
thanks for your reply. the problem is that i drcrease the time step size ,but the problem also appear. i think the problem may be caused by the surface tension
Old   July 4, 2017, 02:44
Ahmed Alkaisi
Hi all,
Do you have any update?
Old   January 23, 2019, 02:22
Default UDF evaporation, standard state enthalpy specification?
vidyadhar
vidyadhar is on a distinguished road
Hi all,
Hello Kimia,
I have also written an UDF to simulate evaporation. The UDF can be found in the link below:
UDF with VOF method to predict evaporation mass/heat flux at vapor-liquid interface
But, I am also facing similar problems:
1) The interface is moving but faster than predicted by analytical solution of Stefan problem.
2) For large time steps, I am also facing divergence problems.
I request you to go through the above link and kindly let me know if there is any mistake in the UDF.
Also, how to specify the Standard state enthalpy(J/kgmol) values in Fluent so that required Latent heat(J/kg) is accomplished. Can I specify any values of standard state enthalpy such that the difference (in values between the two phases) divided by molecular weight of liquid or vapor gives the desired latent heat?
Thanks in advance!
vidyadhar
vidyadhar is offline   Reply With Quote
Old   May 26, 2020, 01:19
Zicheng Li
Liz1219 is on a distinguished road
Can you upload your file and study it together?
Liz1219 is offline   Reply With Quote
courant number, evaporation, phase change, timestep, transient 2d
Phase Change Modeling of water Amar Kad CFX 4 January 11, 2016 18:09
it is possible tu simulate water phase change with fluent 14 or 15? kh91 Fluent Multiphase 1 June 13, 2014 09:58
Modeling of evaporative cooling pad on ANSYS Fluent Vishnu_1991 Fluent Multiphase 0 June 5, 2014 16:17
modeling phase change and homogeneous bubbles in many cycles dwtme FLOW-3D 12 January 1, 2013 05:57
phase change with CFX aximefu CFX 5 March 28, 2012 04:38
