Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent - "No user defined functions have been loaded" error!!!!
Like Tree1Likes
  • 1 Post By srrmm27
Old   February 6, 2017, 10:17
Default Fluent - "No user defined functions have been loaded" error!!!!
srrmm27
srrmm27 is on a distinguished road
Hey everyone,
I am trying to simulate a multiphase flow model in a heat pipe using VOF and udf method. I opened fluent via Visual studio 2013 x64 cross command prompt so as to fix the 'nmake' error and I have compiled my UDF successfully.And after loading the compiled udf, when I select 'user-defined' option in Define -> Phase -> Interaction -> mass, I get the error message:"No user defined have been loaded". I also set the Linearized mass transfer to "no" using "solve -> set -> expert" command from TUI, but I still get the error.
When I googled it, I found that there is problem with "loading udfs" in Ansys16 cracked version, so my question is: is there a fix for this issue for the cracked version, or is there any other version of ansys that doesn't result in this kind of error?
P.S: I have also tried to load udf using the Define -> user-defined -> functions ->intrepreted. But it gives me a error in a line that is beyond the last line of my sourceterm. The error it throws is "C:\\Users\\XXXX src\\sourceterm.c: line 65: label "store_vof_norm" not found (pc=58)".
Any help is appreciated.
Cheers,
srrmm27
My sourceterm.c:
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "metric.h"
#include "flow.h"
#include "sg.h"
#define T_SAT 373
#define LAT_HT 2455e3
DEFINE_SOURCE(vap_src,cell,pri_th,dS,eqn)
real m_dot_v;
Thread *mix_th, *sec_th;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th,1);
/*m_dot_v=0.0;*/
if (C_T(cell,mix_th)>T_SAT)
m_dot_v = 0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*(C_T(cell, mix_th)-T_SAT)/T_SAT;
dS[eqn] = 0.0;
else if (C_T(cell,mix_th)<T_SAT)
m_dot_v = -0.1*C_VOF(cell,pri_th)*C_R(cell, pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT;
dS[eqn] = -0.1*C_R(cell,pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT;
return m_dot_v;
DEFINE_SOURCE(liq_src,cell,sec_th,dS,eqn)
real m_dot_l;
Thread *mix_th, *pri_th;
mix_th = THREAD_SUPER_THREAD(sec_th);
pri_th = THREAD_SUB_THREAD(mix_th,0);
/*m_dot_l=0.0;*/
m_dot_l = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*(C_T(cell, mix_th)-T_SAT)/T_SAT;
dS[eqn] = -0.1*C_R(cell,sec_th)*(C_T(cell,mix_th)-T_SAT)/T_SAT;
m_dot_l = 0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*(T_SAT-C_T(cell,mix_th))/T_SAT;
dS[eqn] =0.0;
return m_dot_l;
DEFINE_SOURCE(enrg_src,cell,mix_th,dS,eqn)
real enrg_dot;
Thread *pri_th, *sec_th;
enrg_dot = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*LAT_HT*(C_ T(cell,mix_th)-T_SAT)/T_SAT;
dS[eqn] = -0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*LAT_HT/T_SAT;
enrg_dot = 0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*LAT_HT*(T_ SAT-C_T(cell,mix_th))/T_SAT;
dS[eqn] = -0.1*C_VOF(cell,pri_th)*C_R(cell, pri_th)*LAT_HT/T_SAT;
return enrg_dot;
Ahmed Alkaisi likes this.
srrmm27 is offline   Reply With Quote
Old   February 6, 2017, 10:30
Ahmed Alkaisi's Avatar
Ahmed Alkaisi
Ahmed Alkaisi is on a distinguished road
Send a message via Skype™ to Ahmed Alkaisi
Originally Posted by srrmm27 View Post
Hey everyone,
Cheers,
srrmm27
My sourceterm.c:
#include "udf.h"
#include "mem.h"
#include "metric.h"
#include "flow.h"
#include "sg.h"
#define T_SAT 373
real m_dot_v;
/*m_dot_v=0.0;*/
dS[eqn] = 0.0;
return m_dot_v;
real m_dot_l;
/*m_dot_l=0.0;*/
dS[eqn] =0.0;
return m_dot_l;
real enrg_dot;
return enrg_dot;
Can you help me in multiphase evaporation - condensation, please? 😅
Sent from my SM-G900I using CFD Online Forum mobile app
Ahmed Alkaisi is offline   Reply With Quote
ansys16.0, fluent - udf, multiphase modelling, vof phase change
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
