Modelling blast furnace layered burden in ANSYS Fluent, convergence issue? |
November 27, 2016, 23:22 |
Rep Power: 10 |
I am modelling layered burden in blast furnace for producing pig iron. I would like to know the effect of layer thickness in the heat transfer between ascending hot gas and descending alternating burden layers. According to User's and Theory Guide, I am using Eulerian Multiphase with k-epsilon tubulence model and enabled energy equation for the heat transfer calculation. I create the model as 2D axis-symmetry in steady state condition. After several trials like redefining the mesh, calculating all input values based on theory, I still find AMG solver divergence results mainly in mp x-momentum and pressure correction. When I change the pressure setting into selective and using CG stabilizer in AMG solver window, I will find AMG divergence in k calculation. All divergences happen in the first iteration.
Do I set the model wrong or is just the problem couldn't suit in Fluent? What should I do to get the convergent result? Thank you for reading this question and I am really looking forward to hearing your answers since I am literally confused what to do next.* |
August 24, 2018, 14:27 |
Emerson
Rep Power: 8 |
Hi, did you solve the problem? I'm doing a blast furnace simulation too with fluent and I'm facing problems with my heat transfer between my granular (coke) phase and the gas phase.
fluent 14 to fluent 15. |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
Fluent Adjoint Solver Convergence Issue? | ex10148 | FLUENT | 2 | July 25, 2016 14:41 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
Convergence issue in Fluent | dibs87jg | FLUENT | 0 | April 20, 2011 04:52 |
