Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Open Channel Flow in a Pipe
Like Tree1Likes
  • 1 Post By sebastianbn
Old   October 11, 2016, 02:10
Default Open Channel Flow in a Pipe
Sebastián Barragán
sebastianbn is on a distinguished road
Hi!
I need some help setting up an open channel flow problem.
It consists in a sewer pipe, with very small slope, which should have water flowing up to the 85% of it's cross section.
I haven't been able to set this initial boundary condition so that there is water and air...
Any help would be very useful.
Thanks,
Sebastián
sebastianbn is offline   Reply With Quote
Old   October 14, 2016, 12:00
Salman Sakib
salmanayon is on a distinguished road
Create velocity inlet and pressure outlet surface and boundary conditions, then activate open channel flow.
salmanayon is offline   Reply With Quote
Old   February 27, 2017, 04:12
Masoud Ravan
masoud.ravan is on a distinguished road
Hi, I want to simulate an open channel with fixed water level at inlet and outlet but I do not know how to fix the water level, I have used OPEN CHANNEL FLOW but after simulation results showed same water level at inlet and outlet...Do you know why?
masoud.ravan is offline   Reply With Quote
Old   March 6, 2017, 10:25
Maryam Alih
mary.alih is on a distinguished road
Hi, I want to do the same simulation. Have you found any solution?!
thanks
mary.alih is offline   Reply With Quote
Old   March 22, 2017, 08:07
Sebastián Barragán
I've used pressure inlet and pressure outlet and it seems to work...
But I have the same problem mentioned above, it appears that after the simulation both inlet and outlet, even I set different elevations for each one, they end being the same.
Old   March 22, 2017, 08:14
Sebastián Barragán
Hey! Thanks for answering back.
How do you use a velocity inlet with OPEN CHANNEL FLOW? When I try to use it like that it says that a velocity inlet can't be used with the OPEN CHANNEL FLOW...
My case is a 3D pipe
mohammed mahmoud likes this.
fluent, open channel flow, pipe, vof
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Question on the boundary condition for open channel flow, please help! ripperjack OpenFOAM Running, Solving & CFD 0 September 13, 2013 12:44
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
