July 12, 2016, 03:48 |
Divergence detected in AMG solver
Dear Sir/ Madam,
I need your assistance, please. I see the following error message after run calculation of ANSYS-Fluent. “Divergence detected in AMG solver: temperature” How can I overcome this problem, please? Regards, Ahmed Alkaisi |
July 12, 2016, 20:20 |
#2 | |
Rep Power: 10 |
1) check for all the boundary conditions and models to be set correctly 2) disable the energy equation to see if the model converges without energy equation 3) Decrease under relaxation factors 4) Use transient with smalll time step 5) check your mesh and the quality of the mesh to be reseonable |
July 12, 2016, 22:37 |
#3 | |
I work on fluent solver I have transient multiphase VOF with solar ray tracing some friends told me to check the temperature limit from solution control according to your answers what is the minimum value of relaxation factor (I used 0.75) what is the smallest time step (I used 30 seconds) Please advise Regards |
July 13, 2016, 15:24 |
#4 | |
Rep Power: 10 |
I am not an expert in this. but when I have divergence I usually start with under relaxation factors around 0.01 and then 0.1 to see what happens. For time step I use 1e-05 or even smaller. There is a discussion topic on this, You can check it out: http://www.cfd-online.com/Forums/flu...mperature.html Good luck. |
July 13, 2016, 19:06 |
Thank you very much
All the best for you |
Divergence detected in AMG solver: pressure correction | xinquanzhoucn | FLUENT | 5 | July 21, 2014 05:49 |
Divergence detected in AMG solver: temperature | otubaba | FLUENT | 7 | October 29, 2013 09:39 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 04:44 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
