Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Set Free Surface Level
Like Tree1Likes
  • 1 Post By ANKURIITD
Old   March 9, 2016, 09:17
Default Set Free Surface Level
Eunjin Kang
pygmi is on a distinguished road
Hello, Fluent users,
I'm trying to simulate the air-water flow in a simple lectangular channel.
The channel is parallel to the ground.
Because there are paddle wheels at the inlet and outlet, water level is constant and maintained along the channel.
I want the free surface levels at both the inlet and outlet to be the same.
To make the system simple, I removed paddle wheels and set the boundarys as pressure inlet/outlet.
I use VOF model and set Eulerian two phase.
I can specify free surface levels at both of pressure inlet and outlet. (boundary conditions)
I have a question in that point.
Does the program calculate the free surface level at the outlet from the boundary condition of the inlet, automatically? If so, is calculated outlet surface level and inlet surface level the same?
Or
Should I specify the levels at both the inlet and outlet the same?
I will be very grateful for your help.
pygmi is offline   Reply With Quote
Old   February 27, 2017, 04:16
Masoud Ravan
masoud.ravan is on a distinguished road
Or
Hi
Did you get your answer?? I have the same problem with OPEN CHANNEL FLOW? How can I fix the water level?
Thanks in advance
masoud.ravan is offline   Reply With Quote
Old   February 27, 2017, 08:14
ANKUR GUPTA
ANKURIITD is on a distinguished road
Originally Posted by masoud.ravan View Post
Hi
Thanks in advance
use open channel VOF model in fluent. By enabling this condition at pressure inlet and pressure outlet you just give free surface level and bottom surface. It will automatically calculate the free surface and will patch the secondary phase from free surface to the bottom surface.
You can check it by plotting the contour of volume fraction at any surface after initialization.
ANKURIITD is offline   Reply With Quote
Old   February 27, 2017, 12:21
Masoud Ravan
Thank you very much
but how can I initialize the problem?
Old   February 28, 2017, 04:50
ANKUR GUPTA
Thank you very much
after setting up the boundary conditions, solution methods and solution control, go to the solution initialization dialog box and setup the followings:
initialization method: standard
compute from: up inlet
reference frame: relative to the cell zone
open channel initialization method: flat
now see the magnitudes of the variables in the initial value box, here just check the velocities. let the water/secondary phase volume fraction be 0.
click initialize.
wfffff likes this.
About Level Set Method kevinLL OpenFOAM Programming & Development 3 August 1, 2015 10:25
[snappyHexMesh] Edge refinement ashghan OpenFOAM Meshing & Mesh Conversion 4 May 13, 2014 06:45
Free Surface not exactly at mean water level FluidH CFX 6 March 21, 2011 02:55
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 20:36
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
