DPM parcels and steady/unsteady time step size |
March 1, 2016, 20:46 |
Rep Power: 13 |
If interaction with continuous phase is not important and is not modeled, does having parcels or a certain number of particles even important?
Also, what if unsteady tracking of particles is not turned on, what is the time step used for the integration of particle equations then? I couldn't find this in the manuals. |
March 2, 2016, 17:03 |
#2 | |
Rep Power: 18 |
If unsteady tracking of particles is not turned on, then you're using steady tracking. Fluent chooses a time step and then refines this step to achieve a set tolerance (default of 1E-5). You can modify the DPM time step via the DEFINE_DPM_TIMESTEP macro. |
steady/unsteady | zwdi | FLUENT | 9 | September 23, 2003 06:07 |
