Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
mark multiple region in multiphase flow in fluent
Like Tree1Likes
  • 1 Post By silent2608
Old   February 10, 2016, 06:53
Default mark multiple region in multiphase flow in fluent
rishabh gupta
rishabhgupta is on a distinguished road
Hello friends, I am simulating the flow of Taylor bubbles in stagnant fluid in slug flow. I have successfully simulated with single bubble. But now with multiple bubbles I facing problem with marking multiple bubble region. please guide me how to do this.
Thank You
rishabhgupta is offline   Reply With Quote
Old   February 10, 2016, 16:51
silent2608 is on a distinguished road
adapt region -> mark several (!) zones for your bubbles, then go to "manage" inside adapt region window and use the "combine" function to combine your regions into one new combined region. now you can use this combined region to patch your bubbles in solution initialization window
you can also realize more complex regions to patch via udf (google patch region udf or something, there are also some examples in the manual), but for simple geometries adapt region window is fine
rishabhgupta likes this.
silent2608 is offline   Reply With Quote
Old   February 12, 2016, 02:46
rishabh gupta
Thanks buddy !! works like a charm
slug flow, taylor bubble
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
