Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
create a mixture as a material in fluent
Like Tree1Likes
  • 1 Post By saddy
Old   February 3, 2016, 13:33
Default create a mixture as a material in fluent
Oula
Oula is on a distinguished road
Hello everyone, I am using ANSYS Fluent to do heat transfer modelling. The fluid domain in the case that I am dealing with, is a mixture of 75%H2 AND 25% 3NH. I did some reading on how to creat mixture and I did attempt, which is I don't know if it is correct or not, which is as follow:
  1. first, I enabled the species transport from Models.
  2. I chose hydrogen-air from mixture material.
  3. In the material panel, I got the mixture and underneath there was a list of species that are relevant to that mixture. Those are H2, O2, H2Ogas and N2.
  4. Then I opened the original fluid panel. I cahanged the material type to mixture and the panel updated itself.
  5. In the same panel and within the properties section, there is a field of mixture species. I clicked on edit I got box message divided into two sections, available materials and selected species.
  6. I removed air, water vapor and oxygen from the selected species field.
  7. finally I got H2 & N2 in material > fluid > list.
Can anyone please tell me if what I have done is right and what next?. I still didn't get my mixture.
Thank you in advance for your help.
Regards
Oula
Oula is offline   Reply With Quote
Old   February 6, 2016, 18:14
Cool Solution
sandy
saddy is on a distinguished road
IN my opinion you can create a mixture as a new material by knowing its properties like density , viscosity thermal conductivity etc. and enter these in fluent database.
Oula likes this.
saddy is offline   Reply With Quote
Old   February 11, 2016, 07:55
Default Thanks a million
Oula
Thank you Saddy so much for you reply. Your answer helped me a lot. I am really grateful.
Regards
Oula
Steam Mixture material for Wall condensation coolcrasher CFX 2 October 19, 2015 10:23
Create Mixture Material efirvida FLUENT 0 December 4, 2010 15:01
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
